Old 07-28-2012, 11:16 PM   #1
Mo707
Mo707's Avatar
3rd gear grind
Anyone one else having trouble getting into 3rd gear?
Its happened 3 times today. I have almost 2k miles on there. Hate hearing my gears grind.
It could just be me. I learned how to drive a stick in this car and i have it down..
Any suggestions?
Mo707 is offline   Reply With Quote
Old 07-28-2012, 11:31 PM   #2
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Beats me... I have just over 400 miles on mine, and I don't have that particular issue.
I think you may be taking the shifter into 3rd gear a little faster than the clutch pedal being depressed properly...
When I first learned how to drive a manual on my Evo, I remember myself encountering similar obstacles... I suppose it comes down to practice, and also better understanding / learning the specific car's shifting and behavior.
Please feel free to correct me if I've mistaken.
Texas BRZ is offline   Reply With Quote
Old 07-28-2012, 11:34 PM   #3
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
maybe letting the clutch off to fast? beats me or not having the clutch all the way in before switching gears is more like it, iv done it a couple times in my stang
Any suggestions?
kendalldwhite is offline   Reply With Quote
Old 07-28-2012, 11:36 PM   #4
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
No problems here... this thread makes me cringe coming from an 8th gen Si. Pleaseeee don't let the 86 have this problem too!
Only gear I've partially grinded was second and I know that was my fault on the clutchwork.
I have noticed that downshifting to fourth from sixth can be a bit tricky and I often go back into sixth. It's kind of funny at times, trying to rev match fourth to overtake only to get into sixth again.. very anticlimactic. Replacing the shift knob earlier today has made this easier for me to avoid!
eriktherod is offline   Reply With Quote
Old 07-28-2012, 11:36 PM   #5
yormaX
Rage your Dream
yormaX's Avatar
Drives: 2015 Scion FR-S
Should've bought the AT with the double clutch gear box. amirite?
yormaX is offline   Reply With Quote
Old 07-28-2012, 11:38 PM   #6
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Is there anything blocking the clutch pedal from traveling all the way down?
sho220 is offline   Reply With Quote
Old 07-28-2012, 11:42 PM   #7
Snowdays
Drives: White 2013 FRS
This happened to be once while driving the car very hard.. it was a painful experience!
I've driven standards for over 10 years, and have not had this issue.. Still I'm hoping that it was my error, not the cars.
Snowdays is offline   Reply With Quote
Old 07-28-2012, 11:56 PM   #8
ChristosG
Drives: 2013 Scion FR-S Hot Lava 6MT
Except it doesn't have a dual clutch transmission. It's a traditional automatic (a very good one apparently) with paddle shifters.
ChristosG is offline   Reply With Quote
Old 07-29-2012, 09:25 AM   #9
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I haven't had any issues yet, im around 1700 mi.
My mkiv jetta had problems with second gear grinding and it was terrible. I really hope this car doesnt have issues with this, and if it does I hope it will come to subaru/toyotas attention quick enough to get it fixed.
Flat Black VW is offline   Reply With Quote
Old 07-29-2012, 09:59 AM   #10
lokvo
Pugilist
lokvo's Avatar
Drives: GT 86 - Hot Lava (AUS Spec)
Just re-iterating something I read from the other threads here, maybe the transmission fluid is low?
"BOO FOR THE GOO" - Everyone
http://www.ft86club.com/forums/image.php?type=sigpic&userid=14259&dateline=134355  2296
lokvo is offline   Reply With Quote
Old 07-29-2012, 10:17 AM   #11
roddy
roddy's Avatar
Drives: '13 Ultramarine
I've never had a grind, but do occasionally get a slight crunch (even that is a bit of an exaggeration) going into 3rd. I swapped the fluid for some fresh synthetic last night, and will put some miles on the car today to see if there is any difference. I don't expect there will be.
Old 07-29-2012, 05:27 PM   #12
Snozzberries
Drives: FR-S Whiteout
I have a harder time throwing into 5th. I don't use 5th a lot, but I have 3rd dropping in pretty clean now. Shift into 3rd once slowly, you will feel how the nob will auto center itself. I also found that under hand shifting for 3rd and paying attention to the nob centering, that helped me learn my spot for 3rd.
Snozzberries is offline   Reply With Quote
Old 07-29-2012, 06:24 PM   #13
Bangduk
Drives: FR-S 2013
It could be the car, does not mean that all of them have same problem. but some can. not long ago new Hondas had similar problem, they use to pop out of 3rd gear. sins its stil under warranty just bring it to dealership.
Bangduk is offline   Reply With Quote
Old 07-29-2012, 06:45 PM   #14
sho220
sho220's Avatar
Toyota's X-Runners had a problem grinding when going into 5th gear. On the second trip to the dealer they just kept it and replaced the tranny...all good after that....
86/BRZ/FRS on Top Gear: When??? FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 20 07-04-2012 12:08 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
Good 'ol Fifth Gear Guff Other Vehicles & General Automotive Discussions 15 12-08-2011 09:20 PM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-08-2010 11:01 PM
