Old 06-04-2014, 02:49 PM   #1
aaguirre123
Drives: sti 2012 sedan
4th gear grind
I took my car to Hamer Toyota, Mission Hills, CA, because of 4th gear grind issue. It would grind when i shift gear into 4th from 3rd especially after 6k rpm. Shop foreman was able to duplicate issue but noted the it was minor since he was able to shift from 3rd to 4th. He did acknowledge that he can hear some noise and noted that there was a minor grind into 4th gear. I was told to leave car and he will notify Toyota of the issue.
The next day I was notified that the transmission will be replaced. Though I would have to wait a long time due to transmission is on backorder. I was happy that Toyota will honor warranty since car only has less than 13k miles. I was also notifed that Toyota might not replace the transmission if it happens again due to some car modification done to car. My mods were flex fuel, air/oil separator, no cat front pipe and tuning done by delicious tuning. In the future, after new transmission installation, foreman advised me to bring car to stock if transmission fails again before bringing car to dealership.
Foreman also test drove new frs cars on lot for comparison and would note similar grind issue. They were not the same level as mine though. He said you really have to make yourself aware of the noted grind. I was going to install a FI but now I don't know. If the transmission is not strong enough, I don't think I should do more modification on the car. This is very disappointing. I want more POWER for this car. What do you guys think?
aaguirre123 is offline   Reply With Quote
Old 06-04-2014, 02:51 PM   #2
Dezoris
Dezoris's Avatar
Some trans have the issues others don't. The other factor is how people drive, shifting technique etc. Hopefully the next trans is smoother.
Old 06-04-2014, 02:56 PM   #3
calibrz
Turbo 86
Drives: GT86
this happen to one of my dude's trans too..good thing is toyota replace it with warranty thought.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 06-04-2014, 02:57 PM   #4
aaguirre123
hopefully you are right but foreman did notified me that new cars on lot have similar grind issues. there were not as bad as mine and one has to make aware of the grind to notice it. he said if you test drive it for the first time and have not driven a brz/frs before you will not notice it. but now that he knows about the issue it is noticable on new cars as well.
Old 06-04-2014, 08:38 PM   #5
djliquidsteele
Drives: Scion FR-S
I just picked mine up today after my transmission took a crap last week. Started out as a 4th gear grind and then made a terrible sound pulling away easy from a light last thursday. Had a metal on metal spinning rubbing sound in every gear but 5th after that. Took it in to the dealer and they put a New transmission in and Covered under warranty. Driving the car now with the new transmission, it was never right to begin with when I bought it in June 2012. Transmission is buttery smooth now, even second gear.
djliquidsteele is offline   Reply With Quote
The Following User Says Thank You to djliquidsteele For This Useful Post:
aaguirre123 (06-04-2014)
Old 06-04-2014, 08:46 PM   #6
Dipstik-sportech
Dipstik-sportech's Avatar
It's a design issue with the synchro system and adding power won't make it worse unless u beat the piss out of it racing people lol.
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 06-04-2014, 09:33 PM   #7
aaguirre123
My transmission was never right from the begining as well. It was not smooth at all. It looks like subaru/toyota has a qc issue with transmission.
Old 06-13-2014, 01:25 AM   #8
aaguirre123
I just got my transmission installed today. No more grind going into 4th from 3rd above 6k rpm. The transmission feels firmer than before. My former car was a 2012 sti. My transmission on the sti is way better than this transmission IMHO. I wish i could transfer a sti transmission on this car.
The Following User Says Thank You to aaguirre123 For This Useful Post:
sosick (08-03-2015)
Old 08-03-2015, 04:58 PM   #9
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
I need mine replaced also
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 09:39 PM
transmission grind in 5th gear Rocket.BRZ Issues | Warranty | Recalls / TSB 7 06-30-2014 10:38 PM
Gear grind downshifting from 6th to 5th JarredH Issues | Warranty | Recalls / TSB 6 03-21-2014 03:52 AM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
