Old 05-30-2021, 04:01 PM   #1
Hsnthethird
Drives: 2015 FRS
Engine light for “replace abs module” but is functioning fine.
Sorry if this is in the wrong place, I’m new here. So I got new wheels and tires for the rear. They were bigger than the front ones so the car went in to limp mode after about 1/3 mile of driving, turned around and went back one abs parked the car. Got new tires that are the same outter diameter as the front and unhooked the battery for a few seconds, then hooked it back up. When I started it back up it was out of limp mode, abs lights gone and drove fine but had a check engine light. Took it to the store, pulled the code and it said replace abs module. Everything seems to be functioning fine though. Is there any way I can “reset” the abs module? It functions fine and I would hate to replace something that isn’t broken. Thanks
Hsnthethird is offline   Reply With Quote
Old 05-30-2021, 04:49 PM   #2
norcalpb
norcalpb's Avatar
I don’t really have an answer on what you should do, and I agree that it’s dumb to replace something that’s not broken, BUT, in your case if you did get a 2017+ abs pump/module you would get a less restrictive traction control system and hill assist.
Until peeps respond my recommendation would be let the car sit with the battery disconnected for a little bit.
Old 05-30-2021, 05:14 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Or you can go to an independent garage and explain to them what you did with the different size wheels, how you took care of that with the new wheels, disconnected the battery in an attempt to reset everything, then ask them if they will connect their professional grade scanning tool to reset the ABS module codes.
But don't let them sell you something you don't need.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 05-30-2021, 06:34 PM   #4
Transport3r
Drives: -
It should reset after disconnecting power and then about a mile of driving.
Transport3r is offline   Reply With Quote
WTB: Back-up Light Module Muskoka800 Canada Classifieds 3 02-27-2019 11:43 AM
crashed Toyota 86 special edition. airbag module's/ reset or replace. JROSA Scion FR-S / Toyota 86 GT86 General Forum 6 12-28-2018 02:26 PM
Kahtec 3rd brake light Module tuckdaddy DIY (Do-It-Yourself) Guides 34 05-03-2017 01:42 AM
You can use the cheapest oil and your engine will be fine. Cjymiller Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-27-2016 02:01 AM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 05:54 PM
