Old 11-23-2020, 07:22 PM   #1
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Idle table logic?
So I'm learning to fiddle around with logging via OFT and exploring the tables in RomRaider a bit. One thing I had a had a mind to try was bump the warm idle a bit to see if it smooths out. Thing is, there are like... 10 idle tables.
Anybody have any idea what triggers the ECU to reference which table? I might be able to make more informed adjustments that way.
Cephas is offline   Reply With Quote
Old 11-23-2020, 07:38 PM   #2
tomm.brz
Drives: brz 2017 hksv2
make them all the same
Old 11-23-2020, 08:54 PM   #3
Cephas
Cephas's Avatar
I was about to do that, but surely there's some reason for all of these tables, and the differences in them?
Old 11-23-2020, 10:40 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
All mine are the same
Old 11-24-2020, 03:49 AM   #5
tomm.brz
we don't know,different requirements for each one to activate or possibly residues of older generations of calibrations.... just put all the same and don t think about it
Old 11-24-2020, 04:16 AM   #6
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I was curious also! I set mine the same on my e85 tune and upped cold start rpm`s . Plus upped fuel on cold start V4.03 maps. Nice and stable now.
gen3v8 is offline   Reply With Quote
Old 11-24-2020, 11:20 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Your probably right, I was never able to find a def on what is what. Based on other tables I would think that "B" is the standard table but
My car, a 13', using a tune based off an OFT 2.7 rev only has idle tables going to "F". OP has 3 extra tables.
Old 11-24-2020, 11:54 AM   #8
Contender
You change all the values that are 650 through 800 to whatever you want the idle to be set at.
Contender is offline   Reply With Quote
Knock Sensor Control Logic ztan Software Tuning 9 07-04-2024 03:29 PM
Car guys logic to picking a car soap No1der Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 35 08-13-2015 03:24 PM
Bonded Logic Sound Insulation - anyone tried it? robwbright Electronics | Audio | NAV | Infotainment 4 06-10-2014 11:55 AM
Mustang Dyno Day at West Palm Beach HP Logic hypermax Southeast 19 02-14-2014 12:52 PM
Halo Light Logic Modification? feedbag Cosmetic Modification (Interior/Exterior/Lighting) 9 01-28-2013 11:33 PM
