Old 11-07-2015, 07:01 AM   #1
ztan
Drives: Toyota 86
Knock Sensor Control Logic
Following @Td-d's work on the ROMraider forums here:
http://www.romraider.com/forum/viewt...hp?f=40&t=8615
I had a look at the A01G ROM with ScoobyROM.
Knock sensor calibration table was easy to find using Td-d's ScoobyROM method, unpicking the knock control logic is quite difficult. There is also a table that looks like it uses FLKC table offset as an input - possibly a threshold. All highly experimental.
Welcome any input into deciphering the knock logic.
Code:
    <table name="Knock Sensor Calibration" storageaddress="11DF48">
      <table type="Y Axis" storageaddress="11DDEC" />
    </table>
    <table name="Knock Threshold" storageaddress="11612C">
      <table type="Y Axis" storageaddress="1160A0" />
    </table>
    <table type="2D" name="Knock Sensor Calibration" category="Ignition Timing - Knock Control" storagetype="uint16" endian="big" sizey="87" userlevel="4">
      <scaling units="ECU value" expression="x-32" to_byte="x+32" format="0" fineincrement=".5" coarseincrement="10" />
      <table type="Y Axis" name="Knock Sensor" storagetype="float" endian="little">
        <scaling units="volts" expression="x" to_byte="x" format="0.0000" fineincrement=".01" coarseincrement=".1" />
      </table>
      <description>Knock sensor calibration</description>
    </table>
    <table type="2D" name="Knock Threshold" category="Ignition Timing - Knock Control" storagetype="float" endian="little" sizey="35" userlevel="5">
      <scaling units="ECU value" expression="x" to_byte="x" format="0.0000" fineincrement=".5" coarseincrement="10" />
      <table type="Y Axis" name="FLKC Offset" storagetype="float" endian="little">
        <scaling units="Offset" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="1" />
      </table>
      <description>?? Knock threshold by FLKC offset </description>
    </table>
ztan is offline   Reply With Quote
The Following 3 Users Say Thank You to ztan For This Useful Post:
elBarto (11-07-2015), Kodename47 (11-07-2015), solidONE (11-07-2015)
Old 11-07-2015, 11:43 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The stuff that would be really handy to have are the per cylinder thredholds with the appropriate logging parameters.
I doubt that anyone will change the sensor cal.
How does the lower one work?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-07-2015, 12:19 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
Just FYI (stumbled across this while learning romraider):
http://www.romraider.com/forum/topic1840.html
http://www.romraider.com/RomRaider/H...ndKnockControl
http://forums.nasioc.com/forums/show....php?t=1433675
I apologize if you have already found this.
Old 11-07-2015, 03:54 PM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Nice! (subbed)
Intent > Content
Old 11-07-2015, 05:38 PM   #5
ztan
Drives: Toyota 86
No real idea, but the value that gets passed to the 2D table is the FLKC cell offset - this reads 0-4 in the first RPM range as load increases, then 5-9 in the next RPM range... 35 values in all for 5 load ranges and 7 RPM ranges.
I played around with reformatting the table to the following, which makes me suspect that this is a table defining knock threshold or sensitivity per FLKC cell. The logic is very complex and I am nowhere close to unravelling it:
Code:
    <table type="3D" name="Knock Threshold" category="Ignition Timing - Knock Control" storagetype="float" endian="little" sizex="5" sizey="7" userlevel="4">
      <scaling units="ECU value" expression="x" to_byte="x" format="0.000" fineincrement=".2" coarseincrement="1" />
      <table type="Static X Axis" name="" sizex="5">
        <data>FLKC Load Range 1</data>
        <data>FLKC Load Range 2</data>
        <data>FLKC Load Range 3</data>
        <data>FLKC Load Range 4</data>
        <data>FLKC Load Range 5</data>
      </table>
      <table type="Static Y Axis" name="" sizey="7">
        <data>FLKC RPM Range 1</data>
        <data>FLKC RPM Range 2</data>
        <data>FLKC RPM Range 3</data>
        <data>FLKC RPM Range 4</data>
        <data>FLKC RPM Range 5</data>
        <data>FLKC RPM Range 6</data>
        <data>FLKC RPM Range 7</data>
      </table>
    </table>
Old 11-07-2015, 11:39 PM   #6
steve99
could it be something like this table in romraider learning view, buy i suppose it would be in ram as its learned values ?
Old 04-14-2024, 11:14 PM   #7
Compelica
Compelica's Avatar
Drives: 86 GT
Hi @callisto - any idea if these FLKC values are stored anywhere in RAM?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 04-14-2024, 11:18 PM   #8
callisto
Drives: 2019 Subaru BRZ
That’s an excellent question, it’ll take a bit to find out but I’m certain they’re in there, that tool is reading them. (Note to self, read every ztan post.)
callisto is offline   Reply With Quote
Old 04-15-2024, 02:21 AM   #9
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks. Have not used the Learning View before, it could possibly just be logging values across different load / RPM ranges as the car is driven.
Never thought of this, but not sure how IAM/FLKC persists when the car is turned off... does that mean the ECU and the RAM is kept in a low power state? @AussieBRZ ?
@ztan has a lot at his disposal as well, it was him who worked on the pre-facelift flex-fuel tunes I believe.
Old 07-04-2024, 03:29 PM   #10
callisto
Aha, I recognize that memory address, I've been looking into this previously.
S10C/FFF815E0, K00G/FFF810B4 - there are 35 pairs of (A, B) floats, stored in the order A1 B1 A2 B2 A3 B3 etc. The FLKC values you see in datalogs derive from the A-side.
Yes, the ECU RAM is kept alive by the battery, which is why pulling the battery or fuse resets the ECU. There's an EEPROM storing VVT learned values, which I want to look into more someday.
(Also: S10C/FFF816F8 is the start of a series of unsigned shorts that is storing what is likely FLKC counters of some sort. That's where my research left off, so I don't have any details for this yet.)
The Following User Says Thank You to callisto For This Useful Post:
Compelica (07-04-2024)
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 08:49 PM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 09:29 AM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 08:37 PM
