Old 06-03-2012, 08:09 PM   #1
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
Halo Light Logic Modification?
So it looks like the halo lights will only come on under two circumstances: if you have the lights set to parking lights mode or if the actual headlights are on.
I'd like to have the halo lights running at all times, in all cases for these reasons:
  • They look hella baller
  • They're higher up than the DRLs and I feel like they'd do a better job of serving the DRLs' purpose (getting attention so people don't wreck into you)
These are the problems with driving with parking light mode:
  • Orange corner lights also on (some might not consider this a problem)
  • No automatic headlight functionality -- you'll have to switch them to on or auto when it's dark out
  • You have to remember to shut them off when you get out of the car lest you come back to a dead battery
How hard do you guys think it'd be to make the halo lights run in all cases?
feedbag is offline   Reply With Quote
Old 06-03-2012, 09:07 PM   #2
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
You would just need to isolate the halo lights. If you cut the wires, and run a power wire that comes on with the ignition as well as a ground, you'd be all set. I'm not familiar with the car wiring yet, but ideally it would be nice to find the junction/plug where they plug inside the car, which would make this MUCH easier! I need to download the service manual, then I might be able to help.
Lil Abner is offline   Reply With Quote
Old 06-03-2012, 09:15 PM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
hm... maybe I'll get rid of the foglights and wire it into the fog light switch on the headlight stalk
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-03-2012, 09:35 PM   #4
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
I really like this idea and for those of us that are getting MT, I would love if you smart guys could figure out and write up a DIY on hooking it up to this...
http://www.ft86club.com/forums/showthread.php?t=7628
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 06-04-2012, 12:16 AM   #5
AlanLGuy
Drives: Raven 6 speed Manual FRS
For that you'd do the same as Lil Abner suggested, Isolate the Halo's, only instead of wiring them straight to ignition you'd route them from the ignition to a switch then to the halo's.
I like the idea of wiring the halo's to be on in all situations.
If anyone knows where to get a copy of the service manual let me know!
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 06-21-2012, 03:47 PM   #6
LexLutherXI
Drives: 2013 BRZ 6MT Limited WR Blue
Halo Lights
Bump.
LexLutherXI is offline   Reply With Quote
Old 06-21-2012, 04:27 PM   #7
was385
Drives: MT WRB BRZ Limited, 2007 911s
yeah, I just don't understand why Subaru didn't just wire them to be on all the time. That would look so much better.
was385 is offline   Reply With Quote
Old 07-31-2012, 04:39 PM   #8
xcelir8brz
Drives: 2013 BRZ Limited
Spent some time trying to figure out the logic via the fuse box/relays without rewiring it on a AT car, and honestly, couldn't figure out an easy way to do it. This is the first time I gave up on something like this.
xcelir8brz is offline   Reply With Quote
Old 07-31-2012, 05:30 PM   #9
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
I would be happy with them being on if your in park or using them as headlights. Do u know who is working on them to be installed into the headlights? Been wanting to put them in my Frs
oso_25 is offline   Reply With Quote
Old 01-28-2013, 11:33 PM   #10
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
bump, anyone figure it out?
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 08:33 PM
Halo ODST Commercial (Epic)!! MR2fan Off-Topic Lounge [WARNING: NO POLITICS] 7 09-14-2015 01:29 PM
Fog light film chadz Cosmetic Modification (Interior/Exterior/Lighting) 0 06-03-2012 02:00 PM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
Downloadable driving data/Toyota encourages modification nate89 Scion FR-S / Toyota 86 GT86 General Forum 22 03-15-2012 09:12 AM
