Old 07-23-2020, 07:10 PM   #1
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Rain drops stay on car for a while
I am sure most of you have gone through this problem and will have some idea about it.
I wash my car weekly and every 4-5 washes apply the turtle spray wax and dry. Also, every 6-8 months I apply Adam’s clay with Adams detail spray.
I just realized that after each rain my car has rain drops while all other cars parked around are dry.
Is this normal? There is so much info and I am a little confused whether it’s good or bad.
Any idea?
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 07-23-2020, 07:42 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Do you always park in the same spot? (Like right beside a water sprinkler?)
LimitedSlip is offline   Reply With Quote
Old 07-23-2020, 07:44 PM   #3
Busybee
Busybee's Avatar
Hahaha. It happens after rain Regardless where I park.
Old 07-23-2020, 07:46 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
That's normal when you have protection on the paint.
Some products have better beading or sheeting properties. Ceramic coatings are better known for water sheeting. But there are some new sealants on the market like meguiars ceramic wax that have pretty good water beading and sheeting without the prep or cost of a coating.
My guess, unprotected cars dry faster because water doesn't pool up, rather just sits thinnly against the paint.
RToyo86 is online now   Reply With Quote
Old 07-23-2020, 07:49 PM   #5
Busybee
Busybee's Avatar
Despite those drops leave little spots once dried (most probably with the dust etc during the dry out) I am completely fine cause you can clean them with a very low pressure of rinse.
Thanks
Old 07-23-2020, 10:57 PM   #6
humfrz
Any idea?
Thanks
Busybee, you're waxing your car waaaay too often! Leave it be till the water doesn't bead up - then wax it.
Anyways, that's the way ol humfrz doesn't do it.
Old 07-24-2020, 01:36 AM   #7
Phuviano
Drives: FRS RS 2.0 #757
I tried ceramic wax about 3 weeks ago. Its ok, nothing special imo. I used turtle wax seal n shine which seems to get good results on YouTube.
I used to be obsessed with detailing my car. I used do clay bar, compound (if necessary), 3 stage polish (that's 3 different polishes with different levels of abrasiveness) and then wax on top. Water used to bead off my car like nothing. With ceramic wax, its not even close to what my car used to do in terms of beading. Spray waxes, and spray on ceramic waxes don't do much. They help beading, but you need to use actual wax, or an actual ceramic coating to get really good water beading imo.
I'm fine with the level of beading the ceramic wax gives me, but it still doesn't last. I fine with it, because I haven't done a full detailing on any of my cars for almost a decade now. I wasted too much of my life on detailing cars. I much rather spend that time on other things.
If you want your water to bead, just get it ceramic coated professionally, not ceramic wax.
Phuviano is offline   Reply With Quote
Old 07-24-2020, 02:50 AM   #8
humfrz
Yep, I hear THAT!
Old 07-24-2020, 08:34 AM   #9
Magyarman
Magyarman's Avatar
Drives: 2016 FR-S series 2.0 , 2002avalon
You want beading ,use Classic Car Wax (no longer made). It was a bitch to put onand even harder to get off. In the rain lt looked like your car had goose bumps.
I use Nu-Finish( yes I know) after using Meguiars #7 show car glaze. It last a good while and beads well.
Magyarman is offline   Reply With Quote
Old 07-24-2020, 11:11 AM   #10
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Any new sealant will do the same. Quick and easy. Jet seal is so much easier to apply and rub off. But my fav is sonax polymer net shield Which goes on like PAM. Both very easy and beading for months. I also use spray wax from sonax or their detailer, those alone will bead up very well. Nowadays even the cheapest Spray detailer Does good beading.
Ernest72 is offline   Reply With Quote
Old 07-24-2020, 05:05 PM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Try Duck wax..
Old 07-24-2020, 05:38 PM   #12
humfrz
WOW! Someone else actually used (tried to use) Classic Car wax!-
Back in the day (1970), I had a BRG MGB-GT and thought it was a "classic", so, I purchased the "best" paste wax money could buy (Classic Car Wax). Early one Saturday morning I started applying the wax, late Sunday night I will still trying to get the last of it off!
I kept it for several years, but finally threw it away without ever using it again!
Old 07-24-2020, 05:42 PM   #13
humfrz
Try Duck wax..
He is NOT trying to clean ducks -
Don't be trying to confuse the non hunters!
Old 07-24-2020, 06:53 PM   #14
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
A true ceramic coating done by a professional will get rid of that problem, but expect to pay good money. Not worth it if your paint is still in good condition and swirl free. I did it on my previous car after it was 10 years old.
SUSPECT_BRZ is offline   Reply With Quote
Help - rpm drops after flashing E85 tune. Joyriding_86 Issues | Warranty | Recalls / TSB 14 11-06-2019 02:42 PM
OFT - IAM drops to .70 on start (resolved) headlikeahole Software Tuning 22 09-10-2016 03:15 PM
Oil drops on pulleys? Where'd they come from? Packofcrows Issues | Warranty | Recalls / TSB 14 02-08-2016 11:28 AM
rpm drops to about 500 JM'sFR-S562 Issues | Warranty | Recalls / TSB 8 01-23-2014 07:07 PM
Scion Drops the ball... dcaff Scion FR-S / Toyota 86 GT86 General Forum 402 12-14-2011 12:40 PM
