Old 09-08-2016, 02:41 PM   #1
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
OFT - IAM drops to .70 on start (resolved)
Searched high and low but didn't find anything on this. I just brought my car in for 60,000 km service, and now my IAM drops to .70 every time I start the car.
The service involved cleaning the injection system, new air filter etc. Since getting the car back it seems to be running fine, had a bit of knock initially but that seems to have resolved itself. The only persistent problem is the IAM drop at start, always from 1 to .70.
It's a 2013 with OFH and I'm running a slightly modded version of the OFH stage 2 tune.
Here is a log that includes the start.
http://www.datazap.me/u/headlikeahol...ta=1-2-3-10-11
headlikeahole is offline   Reply With Quote
Old 09-08-2016, 03:05 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
try better gas...i just switched to 91 tune from 93...tired of searching good gas...
Old 09-08-2016, 03:11 PM   #3
headlikeahole
Wish it was that easy, closest 93 is a 17 hour drive from here. Not to mention I never had issues with 91 until the car was serviced.
Old 09-08-2016, 03:16 PM   #4
zc06_kisstherain
Drives: SWP BRZ
IAM fluctuate. i used to have 0.98 or 0.82 something like that...sometimes it goes to 1 and sometimes it goes less than 1.
when i asked Shiv and other tuners they all say dont worry about it but i got sick of looking at it and tuned to 91 from 93.
Old 09-08-2016, 03:18 PM   #5
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Probably wouldn't be the cause but did you make sure the dealer didn't flash your ecu back to stock during the service?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 09-08-2016, 03:19 PM   #6
headlikeahole
Please read threads before you respond. My IAM is not "fluctuating" It simply starts at .70 the second the car turns over. I'm not getting knock or fuel quality issues.
Old 09-08-2016, 03:29 PM   #7
zc06_kisstherain
Drives: SWP BRZ
ok. sorry..i was just commenting
Old 09-08-2016, 04:08 PM   #8
Nah
Drives: 2013 Scion Frs 6mt
Decrease timing by a couple degrees (base timing b) I doubt you'll lose any power and your IAM will go back to 1
Also scale your MAF
Possibly change avcs to suit your header if you have one
Nah is offline   Reply With Quote
Old 09-08-2016, 04:19 PM   #9
elBarto
elBarto's Avatar
Drives: Toyota GT86
Is there anything rattling when you start your car?
IAM drops are caused when the knocksensor 'hears' knock and sometimes they confuse a rattling exhaust or some other noisy thing to detect false knock.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 09-08-2016, 05:52 PM   #10
headlikeahole
Hmm ill take a listen next time I start it up. Thanks!
Old 09-08-2016, 06:00 PM   #11
steve99
Hmm as the other guy said maybe dealer reflashed ecu at service.
In stock tunes the parameter IAM initial is set to 0.7, in almost all aftermarket tunes IAM initial is set to 1.
I think from memory the oft sets default values for some logging parameters like iam so when it gets no data from ecu on initial switch on it will default say iam to 1, but then it reads data from ecu and finds iam is actually 0.7 , you wont notice that if your iam is actually 1. Also you still had soke fbkc knock in that log -1.75, getting that a few times will hold the iam below 1
OFT tunes keep your original calid but update the base rom to the later factory calid. so delaer thinks you have old rom but you dont. eg a oft A01C tune is actually B01C internally but will report on dealer toll as A01C.
if your car now idles at stock 650 rpm its likey stock tune , oft tunes usually 700 or 750
Just reflash your tune from oft.
Old 09-08-2016, 09:58 PM   #12
Lantana frs
Drives: 13 frs red
Leave it to Steve. I recently had ac serviced. When I picked the car up it felt doggy but has recovered over the last 100 miles. I had wondered if they snuck a reflash in but upon checking idle speed per last post, I realize they didn't.
Lantana frs is offline   Reply With Quote
Old 09-08-2016, 10:10 PM   #13
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
My car does it on stock tune.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-09-2016, 03:37 AM   #14
headlikeahole
Interesting. I was under the impression that if the dealer flashed my ecu, the OFT would no longer "recognize" it as my car (or it would brick it). The dealer was told not to touch the OBDII port and a note was written on the service sheet. Also I wouldn't think they would do that since its a scion and I brought it to a subaru dealer.
I will have a look today to see what tune is running, and probably re-flash either way. Thanks!
