Drives: 2015 Firestorm Frs
Help - rpm drops after flashing E85 tune.
So like I said, after flashing e85 with oft the car is running kind of bad. Before hand I had flash the stg1 oft tune no problems, the car pulled hard and smooth. I ran the tank low filled with e85. Gave it about 20+ miles just low rav driving. And from the first drive from flash I noticed the rpm drops almost to stall when I release the clutch. And the rpm bounce around when driving and letting off the clutch without giving it gas. Ltft and stft is both between 7-/+. I did change and set the launch control to a lower rpm I don't think that would mess with the tune. Should I reflash it with stock e85 tune? Would it have to relearn e85 if I do? Should I give more time to adjust?
Thank for any advice! Tldr; after filling up and flashing e85 car runs rough and drops rpm |
#2 | |
Sent from my GM1915 using Tapatalk |
Will the car have to relearn E85? I have ran stg1 no problem before. I'll try to rewrite later today. Would the LC change have anything to do with it?
#4 | |
#5 | |
#6 | |
Thanks |
#7 | |
Would you think me changing the LC rev limiter could of played apart?
#9 | |
Its possible if you set the LC or FFS rev limt delta to strange values you will get issues. When you flash a car the flash is either sucessfull or fails if you got a partial flash the car wont even start as checksum routine in ecu will fail. Flash a un altered e85 tune and see how it goes Ie no lc or ffs mods and no mods for pops Just standard oft e85 tune Are you running stock intake ?? |
#10 | |
I just re flashed with the e85 stock tune and the car is still running funky. Just sitting here. The rpm is all over the place I just flashed about 10mins ago and was doing the adjusting by driving under 4k rpm @steve99 Last edited by Joyriding_86; 10-20-2019 at 06:46 PM. |
#11 |
Drives: 13 BRZ WRB LTD 6AT
I had a similar problem with stalling before but figured it out. My air filter (a K&N drop-in) was old and was clogging up the intake. I changed the filter and it started to idle fine without stalling. Might want to check the air filter.
| The Following User Says Thank You to aceangel For This Useful Post: | Joyriding_86 (11-06-2019) |
#12 |
Drives: 2013 frs red
My car idled like crap for 30 miles or so after flashing e85 tune. Cleared up though
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Joyriding_86 (11-06-2019) |
#13 |
I didn't even think of that. I'm going to Change it out tomorrow. The car drives alot better now. It's just cold starts are taking 2-3 time before running. Thanks mate.
#14 |
| Lit symbols in dashboard after flashing Xero Limit tune | kev0 | Software Tuning | 19 | 07-07-2019 07:05 AM |
| After flashing A new tune to your car | John27 | Software Tuning | 5 | 06-08-2018 03:03 PM |
| Oil drops on pulleys? Where'd they come from? | Packofcrows | Issues | Warranty | Recalls / TSB | 14 | 02-08-2016 12:28 PM |
| rpm drops to about 500 | JM'sFR-S562 | Issues | Warranty | Recalls / TSB | 8 | 01-23-2014 08:07 PM |
| 86 Insider Drops Mishimoto | 86_Insider | Announcements, Contests, Giveaways | 3 | 09-23-2013 09:40 PM |
