Old 01-21-2014, 02:54 AM   #1
JM'sFR-S562
Drives: 2014 Scion FR-S Whiteout
rpm drops to about 500
sometimes when coming to a stop and going to neutral, sometimes when im completely stopped for a few moments... my regular idle is about 700-750ish. is this bad?
JM'sFR-S562 is offline   Reply With Quote
Old 01-21-2014, 03:31 AM   #2
double0seven
Drives: FRS
Nope, totally normal
double0seven is offline   Reply With Quote
Old 01-21-2014, 07:40 AM   #3
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Since I got my OFT, this doesn't happen to me anymore.
SloS14 is offline   Reply With Quote
Old 01-22-2014, 08:01 PM   #4
ButtonMasher
ButtonMasher's Avatar
Drives: 2013 Ultramarine Scion FR-S
My RPMs drop to about 500 too and my car starts "shaking" until I fully stop. Does this happen to you too?
ButtonMasher is offline   Reply With Quote
Old 01-22-2014, 09:41 PM   #5
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
This is a common issue from the factory, and generally once the tune is put in it is taken care of. Idle minimums just need to be raised as it isn't terrible stable at 500 RPM.
Xero-Limit is offline   Reply With Quote
Old 01-23-2014, 04:09 AM   #6
steve99
As above its generally a factory tune problem on earlier ROM's (tunes)
there is a factory TSB see thread below
http://www.ft86club.com/forums/showthread.php?t=52979
Dealer should reflash to latest spec ROM for free
Most tuners will have the later ROM's or fix it in their tunes, if you want to go that way
Old 01-23-2014, 09:19 AM   #7
Mikem53
Drives: FR-S 6MT
This still occurs even with the latest factory 01C flash under certain conditions.
When the AC is on, coming to a stop as the rpms drop, the idle drops a bit too low, stumbles and recovers to its normal idle speed. Does not occur all the time and is different than the previous idle fix problem.
Mikem53 is offline   Reply With Quote
Old 01-23-2014, 10:54 AM   #8
Xero-Limit
Xero-Limit's Avatar
It does if it is the stock ROM, correct.
Old 01-23-2014, 07:07 PM   #9
ButtonMasher
I have the latest factory tune and this still happens without the AC on. Also there is a sputtering/fluttering sound at idle and during moderate acceleration. Any idea what this is?
Sent from my Nexus 4 using Tapatalk
RPM drops twice after shifting to 3nd gear at ~2500 RPM anewprelusion Issues | Warranty | Recalls / TSB 3 12-23-2013 02:42 PM
86 Insider Drops Mishimoto 86_Insider Announcements, Contests, Giveaways 3 09-23-2013 08:40 PM
Darren drops his phone onto the Formula D track... DarrenDriven Northwest 2 07-22-2013 03:30 AM
For anyone who ever drops things in between the seats.. enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 19 06-12-2013 07:45 PM
Scion Drops the ball... dcaff Scion FR-S / Toyota 86 GT86 General Forum 402 12-14-2011 12:40 PM
