Software Hobbiest
Drives: 2015 FRS
Injector Size (12PSI)
Im looking to turn my boost up from 8psi to 12 psi but im at the limit of my fuel injectors.
What size should i purchase for E85 at approximately 15 psi for some headroom. IDK what size the stock ports are? |
Moutain Runner
1050x
Software Hobbiest
Drives: 2015 FRS
Is that a little extreme for 15 psi. shouldnt 450CC be good enough. Im limited by knock to 15 psi and ring gap so I don't need ''future proofing''
Drives: brz 2017 hksv2
700cc will be fine for 15 psi and E85
you also will need an upgraded fuel pump in the tank, and an electronic boost controller to hook up in the CPC input, but you should actually upgrade to ecutek too and then you can hook it up also on the rear o2 port instead if you need help with the tune then with oft i m here |
Rust bucket enthusiast
I was running 17PSI on 565cc injectors on a decently sized turbo with headroom, about 330WHP and 240wtq. For E85 I'd run a 700cc injector to be safe
ID1050X
Why 1050X? Because it's the smallest injector ID makes, and ID is, hands down, the best you can get. |
what makes them better than the others? closer capacity to the nominal value? better performance at lower duration pulse?
#10 |
Software Hobbiest
Drives: 2015 FRS
Yeah ive been seriously thinking about ECUTEK because from what ive seen is that the DI to PI ratio tables dont work very well on OFT and there are duplicate tables all over the place making it hard to dial in.
#12 |
Software Hobbiest
Drives: 2015 FRS
I picked this one because it looked the most compatible while the reviews show fast spooling and stable waist gating.
Grimmspeed 3 Port Electronic Boost Control Solenoid ONLY - 2015+ WRX |
#13 |
Drives: Q5 + BRZ + M796
Im at 12 psi with E85 using DW 770s.
#14 | |
| Best injector cleaner | JIM THEO | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 01-15-2021 06:55 PM |
| tuning frs maf/injector | QTR FMS | Software Tuning | 80 | 11-01-2018 06:45 AM |
| Injector size question | boostedbrz | Forced Induction | 1 | 02-14-2015 05:10 AM |
| injector covers | blown | Engine, Exhaust, Transmission | 1 | 01-11-2015 05:15 PM |
