Old 01-14-2020, 06:43 PM   #1
JIM THEO
Drives: BRZ 2018
Best injector cleaner
What fuel injector and intake cleaner you guys use?
My Subaru manual says every 15.000km it needs injector cleaner, but as local dealer doesn't stock it I did a search and found the following.
In USA there are two different kits from Subaru and Toyota (SOA868V9150 & 00289-INDKT) that clean intake, throttle plate and injectors, unfortunately none available in Europe.
There is also available a carbon cleaner SOA868V9165 through Subaru and Toyota that needs a special tool to apply it through an intake vacuum hose.
In Australia there is a top engine cleaner SA459, sprayed directly on intake vacuum hose along with a fuel additive.
Finally in Japan Subaru sells a PEA based (75% poly-ether amine!) injector cleaner K0879Y0010 as fuel additive, which is the strongest available product on the market in it's category, but expensive too!
Interesting, almost all Japanese manufacturers have their own PEA based injector cleaners from the same Nippon factory, as it's the most powerful ingredient in every effective intake/injector/engine cleaning product.
I decided to follow this path but Subaru PEA isn't available outside Japan as it's extremely flammable. Fortunately the HKS DDR 52006-AK003 is the same exact product available from some e-shops.
JIM THEO is offline   Reply With Quote
Old 01-14-2020, 06:46 PM   #2
kev0
Drives: '14
That's weird how your manual says to use fuel additives! Here in the US, our manuals says not to
Chevron Techron is what Porsche recommends on their vehicles.
kev0 is offline   Reply With Quote
Old 01-14-2020, 07:13 PM   #3
JIM THEO
Drives: BRZ 2018
Fuel quality maybe?
Techron isn't as good as the original Subaru PEA for sure, as my dealer is also Toyota dealer he puts a Toyota injector cleaner every 15.000km in my fuel tank:
Old 01-14-2020, 07:57 PM   #4
I recommend sending your injectors to a place like FIC.
Grady (05-16-2020), Tristor (01-16-2020)
Old 01-14-2020, 09:51 PM   #5
86MLR
86MLR's Avatar
The twins don't require upper engine cleaner, the D-4S port injectors clean the valves.
Unlike the FA20 in the WRX or the EJ25 in the STI.
GO TOYOTA
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-16-2020, 09:00 AM   #6
JIM THEO
Drives: BRZ 2018
I know what D4S does for our valves but I don't underestimate Subaru schedule that mentions clearly fuel injector cleaner every 15.000Km, may be the injectors themselves need cleaning not the valves!
Old 01-16-2020, 02:38 PM   #7
N_Raged
Drives: 2019 BRZ Sport-Tech RS
What about Seafoam? Haven't heard much about it when it comes to these cars.
N_Raged is offline   Reply With Quote
Old 01-16-2020, 03:46 PM   #8
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It's a boxer, use UEC and subi injector cleaner like subaru use on every other boxer engine with port injection.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
gravitylover (01-15-2021), JIM THEO (01-17-2020)
Old 01-17-2020, 06:44 AM   #9
JIM THEO
Drives: BRZ 2018
That's what I am going to use, Subaru uses the PEA Subaru cleaner in Japan but as I can't find it available in Europe I am going to use HKS DDR which is the same exactly product!
Old 01-17-2020, 01:23 PM   #10
mrg666
pessimistic skeptic
mrg666's Avatar
I use Chevron Techron once a year. Plus, D4S port injectors are supposed to take care of cleaning direct injectors.
Old 05-08-2020, 08:39 PM   #11
viscositosis.rex
Drives: Currently 2018 Taco
Red Line SI-1.
Gumout All-in-One.
viscositosis.rex is offline   Reply With Quote
The Following User Says Thank You to viscositosis.rex For This Useful Post:
chipmunk (09-12-2020)
Old 05-09-2020, 12:44 AM   #12
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
They are? I always read that they were to clean off the valve stems and back of the valves from developing carbon deposits. The inside of the chamber is no more cleaned from port injectors, as it is cleaned from direct injectors.
https://www.caranddriver.com/news/a1...ect-injection/
Carbon deposits—both on the backsides of the intake valves and on tailpipes—are service issues for some DI users.
This raises the density of the incoming charge without boosting and flushes carbon deposits off the intake valves.
If they do clean the DIs then they don't really do them too well. Roughly 50-60k miles on these. At best, they might be cleaning a little, but not the opening, which is what matters.
18k miles on this motor: just to show carbon deposits in the combustion chamber despite PIs and DIs, and to show that the DI injectors are pretty buried.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
gravitylover (01-15-2021), jeepmor (10-05-2022), mrg666 (05-09-2020)
Old 05-09-2020, 06:22 AM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
As I read, D4S is designed to clean direct injectors on idle cycles. Maybe, that engine is not idling enough.
https://www.wardsauto.com/technology...feature-tacoma
The Following User Says Thank You to mrg666 For This Useful Post:
DandoX (05-12-2022)
Old 05-09-2020, 08:10 AM   #14
tomm.brz
Drives: brz 2017 hksv2
our car hot-idles using only DI so i do not understand what they are talking about
The Following User Says Thank You to tomm.brz For This Useful Post:
Irace86.2.0 (05-09-2020)
Headlights cleaner? Teseo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 02-24-2016 03:08 AM
Lucas Fuel Injector Cleaner Discoloration Eski Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 02-03-2015 12:57 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
glass cleaner and SSteel (exhaust tip) cleaner bdanisi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-09-2013 02:56 PM
