Old 10-14-2018, 11:10 PM   #1
QTR FMS
Drives: brz
tuning frs maf/injector
hi
i have an issue while trying to tune my frs my afr wont match target,
my idle is rich and my wot is lean,
on stock injector size and stock maf scale on open loop my idle is either 12.7 or 13.7 depends on coolant temp it gets richer after it warms up not the opposite, and my wot would be around 14.7.
i tried scaling my maf until i did hit fuel cut at 6800rpm my wot was still way off,
i copied maf scale from oft to my ecutek, it got my wot to 13.8, i scaled my injectors to 4% smaller and di pressure to 4% higher pressure,and this got me to 12.9 then i add 2% above 3.5v and this got me close enough as high as 12.7 and as low as 11.95 so there is a huge swing is there a way to fix this without scaling maf and my load is off i want to lower my load
my target is 12.5 at engine load 1 , 12.4 at engine load 1.1.
there is some moment my afr goes down to 11.2 while the ecu targeting 13.6, and there is some moment it would be 16 and ecu targeting 13.6
my main issue now is the load is off because of the maf scale so is there another table i could adjust to get lower load with higher maf scale,and is there another table to fix this fuel issue i know there is no ve table but is there any table would have any effect on fuel calculation?
thanks
QTR FMS is offline   Reply With Quote
Old 10-15-2018, 08:06 AM   #2
Tor
Tor's Avatar
Drives: Toyota GT86
It would help to know what you are tuning. Is it a stock engine, exhaust parts, changes to intake etc.?
Tor is offline   Reply With Quote
Old 10-15-2018, 08:36 AM   #3
QTR FMS
Drives: brz
jdl uel
k&n drop in filter
1320 over and front pipe
stock mid pipe
nameless muffled track pipe
deleted rear 02 (its disabled in af correction #3)
my flexfuel kit says my tank has e11 with 91
my di has rich wot and pi has lean wot but pi still pig rich idle not sure what is my di idle afr as it switches to pi for idle
Old 10-15-2018, 08:40 AM   #4
steve99
It sounds like you have a hardware problem
log the ecu and see what ethanol percent the ecu is registering, dont go off the guage only, it possible the ecu is seeing different reading its not driven of same point as guage.
if thats ok id disconnect flex kit and flash stock tune since you have petrol in tank, then see if same issues.
this will eliminate tune
im assuming injectors are stock
Old 10-15-2018, 08:45 AM   #5
steve99
Originally Posted by QTR FMS View Post
hi
thanks
after reading this again id flash a stock tune and see if that ok
their no reason you need to make big changes to maf scaling or pi injectors or di pressure to run E85 or flex and on NA car no need for speed density or VE tables. the fueling is done via an overall fuel quantity multiplier. what tune system do you have ?
Old 10-15-2018, 08:52 AM   #6
Tor
Tor's Avatar
Drives: Toyota GT86
The stock MAF scale is not going to fit with the JDL header as you experienced.
After that, it sounds to me like the MAF scaling went awry and you then tried to correct the wrong MAF scale by starting messing with the injectors.
Take a few steps back and start over with the MAF scaling. If you get stuck messing with it yourself, you are welcome to shoot me a PM.
Old 10-15-2018, 09:41 AM   #7
QTR FMS
Drives: brz
i still havent made a racerom map for flexfuel i wanted to dial the 91 octane map before spending 350$ on a racerom
and i dont have issue with ecu reading my ethanol percentage on my delicious tuning stage 2 tune , it does run 13.6 at wot with the stage 2 tune
yes stock injector fuel pump stock coil pack and spark plugs stock engine just bolts on
Old 10-15-2018, 09:44 AM   #8
QTR FMS
Drives: brz
with 100% stock tune untouched except af correct #3 im hitting 14.7 at wot this is reading is verified with my external wideband at the rear o2 location
as i mentioned with delicious tuning tune i hit 13.6 wot it used to be 13.2 couple of months ago
Old 10-15-2018, 09:49 AM   #9
QTR FMS
Drives: brz
0.8371790051 0.9806656837 1.1391289234 1.3075114489 1.4888935089 1.6890701056 1.9105120897 2.1500658989 2.4060623646 2.6763558388 2.9624884129 3.2726786137 3.6985657215 4.1244530678 4.5503401756 4.9996123314 5.4867968559 5.9791469574 6.5417423248 7.1405105591 7.7530965805 8.431842804 9.1373271942 9.8681936264 10.717965126 11.5293855667 12.3773603439 13.5 14.5 16.1218147278 17.4229717255 18.7406196594
19.902797699 21.0989990234 22.3377017975 23.627538681 24.9694309235 26.3599185944 27.7959823608 29.2802238464 30.8176250458 32.4108123779 35.7794761658 46.4101486206 55.3706283569 72.0821456909 88.7967681885 123.4995269775 146.0253753662 166.0935211182 199.9080352783 231.8928985596 275.5001525879 333.0964355469
this is my maf scale from 4 months ago this is with stock injector value, it got my afr with 2%+- at wot , but now i tried it again and i got fuel cut at 6800
Old 10-15-2018, 09:58 AM   #10
Tor
Tor's Avatar
Drives: Toyota GT86
What exactly do you mean by "fuel cut"?
The ECU doesn't cut fuel unless you hit the rev limiter.
Old 10-15-2018, 10:08 AM   #11
steve99
If everything stock and your getting 14.7 at full throttle on stock tune you got a hardware issue
make sure you just flash stock ecutek rom ie a completly stock factory tune , no racerom feature file added
ie exhaust leak, bad sensor, bad fuel pump bad injectors something hardware.
this is backed up by you saying your deliceous tune hit 13.6 at wot , thats way lean even on E85 and as you say its getting leaner than a couple of months ago.
Stock tune should hit high 10 afr at wot
Id imagine any tune from reputable tuner for petrol should be targeting low 12 at full throttle on petrol
Old 10-15-2018, 10:10 AM   #12
steve99
Im not understanding this why would a header effect the maf scaling ?
Old 10-15-2018, 10:20 AM   #13
QTR FMS
Drives: brz
i dont know the engine leaned out and started to hit fast rev limiter like the one on neutral not in gear i think i reached load limit and i need to raise the limit like what people do for fi engines
Old 10-15-2018, 10:21 AM   #14
QTR FMS
Drives: brz
he is saying headers improve airflow that the engine runs leaner so it need higher maf scale
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited Element Tuning Engine, Exhaust, Transmission 40 12-17-2013 01:12 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
