Old 04-15-2020, 12:36 AM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
Injector Size (12PSI)
Im looking to turn my boost up from 8psi to 12 psi but im at the limit of my fuel injectors.
What size should i purchase for E85 at approximately 15 psi for some headroom. IDK what size the stock ports are?
dholloway543 is offline   Reply With Quote
Old 04-15-2020, 12:38 AM   #2
Chuckls
Moutain Runner
1050x
Chuckls is offline   Reply With Quote
Old 04-15-2020, 01:38 AM   #3
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
ID 1050X
GenRuleAThumb is offline   Reply With Quote
Old 04-15-2020, 12:45 PM   #4
dholloway543
Software Hobbiest
Drives: 2015 FRS
Is that a little extreme for 15 psi. shouldnt 450CC be good enough. Im limited by knock to 15 psi and ring gap so I don't need ''future proofing''
Old 04-15-2020, 01:57 PM   #5
tomm.brz
Drives: brz 2017 hksv2
700cc will be fine for 15 psi and E85
you also will need an upgraded fuel pump in the tank, and an electronic boost controller to hook up in the CPC input, but you should actually upgrade to ecutek too and then you can hook it up also on the rear o2 port instead
if you need help with the tune then with oft i m here
Old 04-15-2020, 02:13 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I was running 17PSI on 565cc injectors on a decently sized turbo with headroom, about 330WHP and 240wtq. For E85 I'd run a 700cc injector to be safe
Old 04-15-2020, 03:25 PM   #7
CSG Mike
CSG Mike's Avatar
ID1050X
Why 1050X? Because it's the smallest injector ID makes, and ID is, hands down, the best you can get.
Old 04-15-2020, 03:54 PM   #8
tomm.brz
what makes them better than the others? closer capacity to the nominal value? better performance at lower duration pulse?
Old 04-15-2020, 05:15 PM   #9
CSG Mike
CSG Mike's Avatar
pre-mapped for tuning, response, atomization, precision
Old 04-15-2020, 06:41 PM   #10
dholloway543
Software Hobbiest
Drives: 2015 FRS
Yeah ive been seriously thinking about ECUTEK because from what ive seen is that the DI to PI ratio tables dont work very well on OFT and there are duplicate tables all over the place making it hard to dial in.
Old 04-15-2020, 06:49 PM   #11
dholloway543
Software Hobbiest
Drives: 2015 FRS
What is a good electronic boost controller while where on the subject though
Old 04-15-2020, 08:21 PM   #12
dholloway543
Software Hobbiest
Drives: 2015 FRS
I picked this one because it looked the most compatible while the reviews show fast spooling and stable waist gating.
Grimmspeed 3 Port Electronic Boost Control Solenoid ONLY - 2015+ WRX
Old 04-15-2020, 09:51 PM   #13
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Im at 12 psi with E85 using DW 770s.
Old 04-17-2020, 03:16 PM   #14
CSG Mike
CSG Mike's Avatar
Originally Posted by solidsnake11 View Post
Most of Id injectors are just stock bosch injectors decapped. Decapped is where the little end cap with the small holes in them are removed.
If you look they will have the part number ground off. The end will have a cone shape where they machined the cap off.
I think that's an unfair simplification, but yes, all ID injectors in production are Bosch cores.
Best injector cleaner JIM THEO Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 01-15-2021 07:55 PM
tuning frs maf/injector QTR FMS Software Tuning 80 11-01-2018 07:45 AM
Injector size question boostedbrz Forced Induction 1 02-14-2015 06:10 AM
injector covers blown Engine, Exhaust, Transmission 1 01-11-2015 06:15 PM
