Old 03-03-2020, 10:06 PM   #1
sexyslidez33
Drives: 2013 Scion FRS, 2003 Nissan 350Z
Clock stays on with no key in ignition
I have a 2013 Scion FRS base and the radio started making some weird noises, similar to a CD changed back in the day.
I checked today and noticed my clock stays on even with no key in the ignition.
I disconnected the fuse for the radio so my battery won’t die but this is strange to me. Is something wrong with the radio so it’s feeding power to the clock?
Any help in the right direction would be amazing!
Thank You for the help!
sexyslidez33 is offline   Reply With Quote
Old 03-03-2020, 10:22 PM   #2
Impureclient
Drives: 2015 FR-S
Maybe failed ignition switch? Do a Google search for "clock stays on with no key in the ignition".
Lot's of good threads like this come up: https://repairpal.com/why-does-my-cl...y-ignition-544
More likely car has a ghost though, sell ASAP!
Impureclient is offline   Reply With Quote
Old 03-03-2020, 11:51 PM   #3
p1l0t
p1l0t's Avatar
Clock is part of the HVAC system...
https://rover.ebay.com/rover/0/0/0?m...p%2F1922273910
I suggest you pull over somewhere safe with a good atmosphere because you may loose environmental controls.
Old 03-04-2020, 08:11 AM   #4
sexyslidez33
The hazard and seat belt warning still works without the fuse.
But here is a picture of the problem.
Old 03-04-2020, 08:19 AM   #5
Did you try putting the fuse back and see if the power off on reset anything?
The head unit noise is probably a cooling fan going bad. It has been reported as an issue on here before.
Shouldn't impact the clock though.
Does anything else come on when the ignition is off?
Old 03-04-2020, 08:45 AM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
What's that thing with a red circle?
Old 03-04-2020, 09:51 AM   #7
It is the key *****
Old 03-04-2020, 10:20 AM   #8
p1l0t
p1l0t's Avatar
It is the key *****
Hehe I was thinking the same thing but then I recognized it off my Fiancée's 2013 Impreza. No dual climate controls either? How does he drive with women? I thought the radio was aftermarket for a second but then I noticed it says Scion so maybe that's what the factory radio looked like in 2013? Anyway on a serious note I think it might be time to pull out the old multi-meter...
Old 03-04-2020, 10:21 AM   #9
p1l0t
p1l0t's Avatar
Also is your shifter actually gated? (Sorry for getting off topic but it's a free bump anyway)
Old 03-04-2020, 11:35 AM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
It is the key *****
I'm counting the astriks... Can't make out what you are saying...
Old 03-04-2020, 11:55 AM   #11
Don't be a **** you know perfectly well it says *****.
Old 03-04-2020, 12:27 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Okay, let me read it for the twentieth time...
You ******* ******! I can't believe what you "astriked".. I will take it as we are experiencing difficulty with translation..
Old 03-04-2020, 12:59 PM   #13
korhun
Database error
korhun's Avatar
korhun is offline   Reply With Quote
EBC stays on for awhile when engine turns off brosifSmith Software Tuning 3 06-03-2019 01:43 PM
Better Door Stays? theom Cosmetic Modification (Interior/Exterior/Lighting) 18 11-22-2017 11:55 PM
Revs stays high Claymore Engine, Exhaust, Transmission 6 05-27-2016 02:09 PM
Negative FLKC but IAM stays at 1 Tectoniic Software Tuning 6 01-10-2016 04:33 AM
What stays cleaner looking DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 16 01-20-2013 01:19 AM
