Drives: 2015 BRZ Limited
EBC stays on for awhile when engine turns off
So this doesn't seem to be harmful, but it is slightly annoying and I want to make sure it won't shorten the life of the electronic boost controller. I run Ecutek with RaceRom, and I've replaced the CPC solenoid with a Mac brand 3 way mac valve. It works great and I've got my wastegate duty configured near perfection, operating frequency is at 30hz. But, when I turn the car off, the valve will continue to operate for 5-10 seconds then turns off. If I turn the car on but don't start the engine (2 presses of ignition button, no foot on brake) it will also turn on and start vibrating/operating. I can hear it operating at idle when it's on, and this seems normal, but i wouldn't expect it to operate when off. But I'm wondering if it's receiving values similar to what it would at idle, and since it's supposed to be operating at idle it does so when the engine is off too. Any thoughts? I could configure it so the valve duty cycle is 0 at idle as well, but it seems to help not let boost spike when I initially get on the throttle from a stop, because I don't like to strain the engine with big boost and super low RPMs, ~1000. Does anyone have some experience with this, and can confirm if it's an issue or not?
Also I had a thought that perhaps the car is still running some sort of CPC maps, which would operate the CPC soleniod for awhile after it turns off or first turns on to do it's purge cycle, or however that emissions stuff is designed to work. But I'm not sure how you would change this, The cpc cycle output should be replaced with the custom map output I made. I don't think this is the case, but it was an interesting correlation with that OEM function.
Drives: UK GT86
Yes, it does continue to operate when the car is switched off. Found this out with a WMI setup that we powered from that output. The ECU will remain powered for a small period of time and the CPC does do something.
.: Stealth 86 :.
I'd love to be able to completely disable those CPC maps, but it doesn't seem there is an option for that. I'm gonna assume this doesn't hurt the ebcs, even though it isn't able to pass any air through it when the engine is off.
| been awhile since on here......cars beens in storage for 4 months.....cant wait to dr | sledheadguy | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 03-01-2016 06:59 AM |
| Sad Goodbye for awhile... | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 64 | 11-02-2014 08:47 PM |
| Moving in neutral....Engine turns off? | deedz | Issues | Warranty | Recalls / TSB | 23 | 04-23-2013 09:23 PM |
| What stays cleaner looking | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 01-20-2013 01:19 AM |
