Old 01-01-2020, 03:55 PM   #1
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
Lack of throttle responsiveness after header install
Hi guys
I installed an FT86SF UEL Catted header yesterday and found that the throttle feels less responsive at low speeds. Trying to get the engine up to speed in order to get my car moving takes a lot more input than before. We had found a leak from my Perrin 2.5inch midpipe to the frontpipe but fixed it. Any suggestions as to why there’s a lack of responsiveness?
hpanju is offline   Reply With Quote
Old 01-01-2020, 04:13 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Did you get a tune to go with that install?
Old 01-01-2020, 04:24 PM   #3
hpanju
hpanju's Avatar
No I have not, planning on it soon, I’ll need a custom tune though as I have a CAI
Old 01-01-2020, 04:36 PM   #4
DarkPira7e
DarkPira7e's Avatar
Likely the tune is exactly why the car doesn't feel right. Let us know once you get a tune.
Are you also saying you have a cold air intake on the car as well with no tune? Or is it tuned for the CAI?
Old 01-01-2020, 06:14 PM   #5
86MLR
86MLR's Avatar
I've swapped a heap of headers and never needed a tune, I would check your wiring.
Dirty or damaged O2 sensor?
Was it running fine before the header but after the CAI?
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 01-01-2020, 06:33 PM   #6
hpanju
hpanju's Avatar
Yeah no tune with the CAI. I’m running the Grimmspeed so the MAF scalings are very similar to stock.
Old 01-01-2020, 06:34 PM   #7
hpanju
hpanju's Avatar
Actually running fine after the CAI but before the header. Went CAI first then catback then header
Old 01-01-2020, 06:38 PM   #8
86MLR
86MLR's Avatar
I would first check the 2 O2 sensors wiring and connectors.
Did you use anti seize on the O2 sensor thread?, maybe you got some on one or both sensors.
Has it thrown a code yet?
The Following User Says Thank You to 86MLR For This Useful Post:
jcw99 (01-02-2020)
Old 01-01-2020, 06:48 PM   #9
hpanju
hpanju's Avatar
Didn’t use anti seize. Cleaned off the threading when reinstalling into the new header however. Hasn’t thrown a code yet and all the wiring seems to be fine. The car runs perfectly fine and pulls well, it’s just that the throttle feels slightly less responsive than normal.
Old 01-01-2020, 07:03 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Probably during installation battery was disconnected, and thus ecu needs some time to relearn throttle pedal's travel & fuel trims. Search around/google for dead pedal fix and shiv's reset.
The Following 2 Users Say Thank You to churchx For This Useful Post:
86MLR (01-01-2020), Stomachbuzz (01-01-2020)
Old 01-01-2020, 07:48 PM   #11
hpanju
hpanju's Avatar
Actually did disconnect the battery now that I think about it. Will try the dead pedal fix and let you know. Thanks for the help!
Old 01-01-2020, 11:58 PM   #12
Lantanafrs2
Drives: 2013 frs red
It takes 50 miles or so for ecu to adjust
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
jcw99 (01-02-2020)
grams throttle body install, won't start jdair28 Engine, Exhaust, Transmission 34 06-26-2019 12:31 PM
On-throttle under-load "Dieseling" type noise... Header gaskets? Kostamojen Engine, Exhaust, Transmission 5 03-18-2016 08:50 PM
Sucking sound upon throttle after Magnaflow Catback install Thrustin Engine, Exhaust, Transmission 13 05-25-2014 03:05 AM
Creak/Clunk heard after increasing throttle, recent springs install tracerit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-10-2013 04:03 PM
