Old 07-16-2017, 09:27 PM   #1
jdair28
grams throttle body install, won't start
Anyone have any pics of their grams throttle body installed with the 2017 intake manifold? I tried installing mine today but the car wouldn't start. It said I may have to attempt several times, but I couldn't manage to get it to start. Any help would be appreciated. Thanks for your time.
jdair28 is offline   Reply With Quote
Old 07-16-2017, 10:03 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by jdair28 View Post
Anyone have any pics of their grams throttle body installed? I tried installing mine today but the car wouldn't start. It said I may have to attempt several times, but I couldn't manage to get it to start. Any help would be appreciated. Thanks for your time.
I don't have specific knowledge of this install but you should be able to work through the basics. Double check anything you unplugged to install the throttle body has been plugged back in properly. The next thing I'd check is you battery. Beyond that what other mods do you have? Did you change anything else at the same time?
1974 TA22 Celica
2013 86 GT
Old 07-16-2017, 10:18 PM   #3
Hawk77FT
Drives: GTS 86
LIke Turdinator suggested, and also make sure that you installed a gasket in there otherwise, there is no way it will work properly.
Hawk77FT is offline   Reply With Quote
Old 07-16-2017, 11:29 PM   #4
Somerandom18
Drives: 2017 manual BRZ
What year is your car? That thing doesn't fit properly on 2017 without modification.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 07-17-2017, 12:06 AM   #5
jdair28
Thanks for the advice I will try again tomorrow. I have a 2013 FRS with the 2017 intake manifold. I read that the tabs need to be adjusted? I shaved the left tab down for a previous throttle body spacer. Is there something else?
Old 07-17-2017, 12:59 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I could not imagine of installation issues, but grams throttle body might be different. Let us know of the outcome.
Old 07-17-2017, 07:32 AM   #7
steve99
Resinstall thte original throttle body, if car starts it likly iszue with new throttlebody or for some reson its not electricly comparable with 2017.
Old 07-17-2017, 06:07 PM   #8
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Nope not necessarily true anymore. Their current batch of throttle bodies don't require any sort of intake manifold modification to fit properly.
The spacer comes with a drilled hole that the pin/tab on the lower left side sits in. The pin/tab on the upper right side of the intake manifold never got in the way of the throttle body spacer before or after the spacer revision.
If you recently purchased the throttle body from grams directly, your spacer will be the updated version. I purchased mine on July 4th and received the updated spacer.
Here is a pic of the spacer included in my box.
Here is a pic of the throttle body installed on a 2017 intake manifold.
*This was installed on the series yellow displayed at the Grams booth at 86fest yesterdy
TachyonBomb is offline   Reply With Quote
Old 07-17-2017, 08:02 PM   #9
Somerandom18
Oh sweet maybe I'll order one now. 😁
Old 07-17-2017, 08:33 PM   #10
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I talked to grams at 86fest about the throttle body and I was under the impression from our discussion that you have to get the car retuned to tell the pcm that there is more air coming in. Would that be an issue for starting? I am not a tuning guru at all, still learning.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 07-17-2017, 09:07 PM   #11
TachyonBomb
I talked to them too at 86fest. Nothing else is needed for the throttle body to start working. disconnect battery, add new throttle body, connect battery turn on car, turning on car may take a few tries and some pressing of the gas peddle to get it initially started, let idle until warmed up, once warm let idle for 5 more min, turn off, turn on and drive for 10 min. that is what the instructions say.
If it does not turn on at all the given instructions say it could be a faulty wiring harness and to contact them to swap for a new one if it's bad.
Old 07-18-2017, 12:31 AM   #12
Drakiv
Project Shadow
Drakiv's Avatar
Ah ok, good to know. I wanna get one, just wasnt sure about all of that. I just got a 30% off coupon for it too
614whp/421tq on E85
Instagram: Drakiv
Old 07-18-2017, 10:20 AM   #13
jdair28
@TachyonBomb thank you very much for the pictures! It looks like the spacer, thermal gasket, and TB are all flush together (at least from the top). Is that the case? If I line everything up so that the hump at the top is in line with them all, the spacer extends a bit more to the left.
Old 07-18-2017, 12:24 PM   #14
empower-auto
Kouki-Monster
empower-auto's Avatar
This is a very easy, straight forward, bolt on part. The coolant bypass and plug in the TB are simple. Plug the harness in and follow the startup procedure in the instructions.
This booted up first try with my 2013 w/ 2017 Manifold and it had learned idle within a few seconds.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
OEM throttle body nikitopo Engine, Exhaust, Bolt-Ons 10 01-07-2024 11:50 AM
OFT and Grams throttle body 86Speedy Software Tuning 27 05-05-2017 05:21 PM
