Old 09-08-2013, 01:22 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Creak/Clunk heard after increasing throttle, recent springs install
I had a shop install the Eibach Prokit springs a week ago and have been driving strictly on the freeway to work and minimizing miles until I get my alignment done. However I've noticed on city driving, when I'm driving slowly then hit the throttle a bit, there's a noticeable light creak/clunk sound from the rear. It's reproducible I would say more than half of the time. I've never noticed this before. I doubt it, but would an alignment fix this?
tracerit is offline   Reply With Quote
Old 09-08-2013, 08:15 AM   #2
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
the short answer is no, it is something else...
86•BRZ is offline   Reply With Quote
Old 09-09-2013, 09:44 AM   #3
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Check the sway bar links and if not it could be your left rear axle going. Lots of people having issues with it.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-09-2013, 10:39 AM   #4
Dezoris
Dezoris's Avatar
What was your clunk issue?
Old 09-09-2013, 11:24 AM   #5
feldy
feldy's Avatar
inner cv joint. Got it replaced under warranty a few weeks ago.
Old 09-09-2013, 11:55 AM   #6
Dezoris
Dezoris's Avatar
On the left axle? Was it just under load and unloading it made the noise?
Old 09-09-2013, 12:24 PM   #7
feldy
feldy's Avatar
Yep. It sounds just like the videos that were posted in the axle breakage threads.
Old 09-09-2013, 12:26 PM   #8
husker741
http://www.ft86club.com/forums/showthread.php?t=43936
Same sound?
husker741 is offline   Reply With Quote
Old 09-09-2013, 12:27 PM   #9
feldy
feldy's Avatar
heres the thread with more info and video http://www.ft86club.com/forums/showthread.php?t=41762
Old 09-09-2013, 12:41 PM   #10
Dezoris
Dezoris's Avatar
Good to know looks like I will be keeping close to stock ride height!
Old 09-09-2013, 12:56 PM   #11
feldy
feldy's Avatar
Your still throwing money into this car? I'm happy with the .75 inch drop that the rce springs do. That's the same recommend drop that comes with the trd coils from japan.
But some with stock ride heights are seeing the same issue. Its a matter of driving style the dealer might say. hehe
Don't worry Turbozki gots you covered.
Old 09-09-2013, 12:59 PM   #12
Dezoris
Dezoris's Avatar
We did our suspension install on the weekend and have a nasty clunk from left rear. Does not sound like axle noise. Trying to rule out shock/plates or sway bar links.
Going to make sure we don't go passed 10mm drop.
Old 09-09-2013, 02:09 PM   #13
feldy
feldy's Avatar
Can you get some go pro footage of it.
Old 09-09-2013, 02:48 PM   #14
Dezoris
Dezoris's Avatar
I can get audio probably not video.
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 01:14 AM
Rear end clunk after H&R Super Sport Spring Install Taber Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-27-2013 08:40 PM
How much should it be to install springs? MiniGuy CANADA 28 05-07-2013 09:44 AM
Lowering Springs install help HATED1 Northwest 6 03-10-2013 03:47 PM
