Old 03-16-2016, 12:36 AM   #1
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
On-throttle under-load "Dieseling" type noise... Header gaskets?
Last couple weeks I've been hearing a new noise with my exhaust, it only happens under load when accelerating usually at lower RPM's. Its loudest from the passenger side footwell, and sounds like an old pushrod Subaru (or an old VW bug if you are less familiar with Subaru's :P ).
There is no noticeable change in performance and no codes are being thrown.
I've had this exhaust setup for a year, and this is a new sound:
Revworks Header
Nameless catted but resonatorless overpipe/catpipe combo pipe
Stock midpipe
Legsport muffler
OFT
TRD intake
Couple videos:
[ame]http://www.youtube.com/watch?v=nUneTAfBr_I[/ame]
Sorry for the black screen, but that was in the dark. You can hear it when I hammer the gas a bit, but its much louder in person than in the vid.
[ame]http://www.youtube.com/watch?v=0Zv2V4khB8I[/ame]
Thats starting up the car and idling (its not the ticking noise at the end)
I'm going to pop off the skidpan Friday and take a look see, and I ordered some new gaskets for the header just in case that is the problem, but I'm hoping someone has had this exact noise so I can be sure before then, thats all... Thanks!
Kostamojen is offline   Reply With Quote
Old 03-16-2016, 01:03 AM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
this comes to mind. your engine is a '13 as well.
http://www.ft86club.com/forums/showthread.php?t=81496
aegisdrgn is offline   Reply With Quote
Old 03-16-2016, 01:30 AM   #3
Kostamojen
Thats a "clack" noise, mine isn't like that.
Old 03-16-2016, 03:22 AM   #4
steve99
look at your long term fuel trims if you have header leaks they will probably be high positive at lower rpm
look for black stains or moisture at joints on a cold start
Old 03-18-2016, 07:04 PM   #5
Kostamojen
Found the problem...
Yup, that entire seem has cracked/separated on the header
Going to have to remove them and have them fixed.
Old 03-18-2016, 07:50 PM   #6
aegisdrgn
aegisdrgn's Avatar
I'm glad I was wrong!
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Stock exhaust gaskets/Perrin 3" gaskets migx333 Engine, Exhaust, Transmission 1 07-10-2015 11:23 PM
Coat stock rims in a "SBC" type color jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-12-2013 08:45 AM
"blipping" the throttle takes more that a blip?! KSC BRZ First-Gen (2012+) — General Topics 49 02-27-2013 07:04 AM
