Remove O2 sensor without header removal
Just put on my new EL JDL header but I am trying to rule out an issue with my fuel trims at idle going wonky. One theory is is the possibily the O2 wideband has gone bad. With a long reach tool can it be removed without removing the header?
2013 Series 10 FRS #553
Drives: 2017 toyota 86
yes
Yea did some googling and with the under tray off it's easy access.
Drives: 14 BSP Edelbrock BRZ
I took mine off from the top. I don't see how you would remove it from the bottom.
Undisputed El Presidente
Drives: Zenki 37J ZN6
Yes, I have pulled mine out from the top using a couple long extensions and a o2 socket
| Stock exhaust manifold/header removal tip | Phuviano | Engine, Exhaust, Transmission | 4 | 12-07-2019 09:53 AM |
| O2 sensor removal without an O2 socket? | H_K | Engine, Exhaust, Transmission | 11 | 08-23-2019 04:07 PM |
| OEM header removal | Last Lemming Alive | Engine, Exhaust, Transmission | 5 | 12-03-2017 01:38 PM |
| e-brake removal, spacer to remove backplate | puma | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-31-2014 06:48 PM |
| how hard to remove tpms sensor? | hanabie | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 10-04-2013 05:46 PM |
