Drives: '13 Scion fr-s
O2 sensor removal without an O2 socket?
Just wondering, would using a regular wrench be alright when removing the o2 sensor during a header install? Not sure if buying the o2 sensor is really necessary.
I Love custom Turbo kits
Drives: Limited BRZ
The problem with an exhaust component is that they are pretty much seized by the heat. A socket is your best bet to avoid stripping the O2 sensor and getting into bigger, more expensive problems.
#3 | |
I plan to do the header install with hand tools but now I'm scared I won't be able to muscle off all the bolts on the header if they're all going to be seized... Any advice? Last edited by H_K; 08-22-2019 at 12:46 PM. |
Drives: 2013 Subaru BRZ
I did this job two weeks ago on my 2013, the exhaust bolts weren't terrible, just make sure you have a variety of short and long wrenches, as well as a variety of shallow and deep sockets. If your socket set does not have an extension and a swivel/ujoint you would be wise to get these before getting under your car.
The show stopper I ran into was the rear O2 was completely, utterly seized onto my OEM manifold. I had to install the plug into the bung my new header, and run without for a week until I ordered a new one off rockauto. I was able to disable some of the rear o2 compensations via my OFT/romraider so that I could get by, but this isn't a long term solution. I would suggest sourcing both rear and front O2's that you could pick up nearby at a moments notice if you get stuck in the middle of the job. |
Drives: 2018 FA24 SWAP BRZ "ANNIE"
Not sure about the plug on these cars, but with my Miata I am able to get the plug through the box end of a 7/8" combination wrench. 7/8" is the O2 size, using a quality combination wrench I have been able to remove them when my O2 wrench bends too much.
Make sure you get a few of the little anti-seize packets at the parts store. Apply this to the threads ONLY, before you re-install the sensor.
DJ
2008 MX-5 PRHT "Violet" 2018 FA24 Swap BRZ "Annie" |
#6 | |
Wheels for Brains
Flare nut wrenches work great too and can be used in other situations, if you don't want to buy a single/whole socket set for one job.
--- As far as getting another O2 sensor, it doesn't hurt to be prepared. Get a generic replacement at an auto parts store or exact replacement at the dealer in case. At worst, you lose some shoe leather and a restocking fee. As others have mentioned, the risk is there that the O2 sensor is seized on and the threads simply get mangled when you pull the sensor off. Mine took some elbow grease to get off, but luckily the threads were good. That being said, it's worth getting an O2 sensor thread chaser as well. |
#7 | |
Drives: Limited BRZ
You could rent the O2 socket from advanced auto parts, (at least here in the states) for free.
Drives: 2013 brz limited / galaxy blue
#9 | |
Dude they cost like three pennies. Just go buy one. Also, make sure the manifold is completely cold (like over night cold) before touching it or it will eat itself and force you to buy another cheap tool (thread tap) and new sensor. |
#10 |
Señor Member
I used and adjustable wrench for mine. But I do live in Australia where the roads are never salted and a non-stainless exhaust will easily live 10 years without issue...
1974 TA22 Celica
2013 86 GT |
#11 | |
He's from Canada, so I'd bet it's going to be pretty nasty.
#12 |
Drives: 2013 Firestorm Red FRS
My stock manifold was pretty rust free, i managed to get it off with an adjustable wrench ¯\_(ツ)_/¯
Its a lot easier to work on if you unplug them from the top, pull the header and unbolt the sensors when its off the car. |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
| Socket Set | MrMista | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-28-2013 03:21 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
| 02 Sensor Socket Size? | swift996 | Engine, Exhaust, Transmission | 6 | 08-19-2013 09:30 PM |
