Drives: WRB 2017 BRZ Limited w/ PP
OEM header removal
I've been reading blogs about removing the header and the rest of the exhaust system. Thing is they always group the headers with the rest of the exhaust. If I am just replacing the header can't I just unplug the O2 sensors, remove the lowe front cover, unbolt where it connects to the overpipe, then unbolt header from the engine? Does anything else require unbolting if I just need to remove the header?
Drives: SWP BRZ
Unplug o2 sensor then remove all bolts from connected pipes. Simple as that for removing header.
Sent from my SM-N950U1 using Tapatalk |
Drives: GT86 2013
You will have to remove the stud-bolts from the stock header. Either that or remove the front-pipe. If you just remove the nuts you wont be able to maneuver the header out of the car.
Use a stud-remover tool, or make your own by tightening two nuts against eachother on the stud. Also, you might want to consider wrapping the header if its stainless. Stainless header on stock exhaust can sound a bit farty, it does so on mine anyway. So i'm having it wrapped next year. Last edited by skogs; 12-02-2017 at 07:47 AM. |
Drives: 2016 BRZ
You can get the stock header with weld studs off without removing the front pipe/over pipe by undoing one bolt on the bottom of front pipe. this allows you to drop the front pipe down about an inch, which will give you enough room to get the header off. That's how I did it anyway.
Drives: GT86 2013
Thats a good tip! But my studs weren't welded, just screwed in there.
Huge E85 fan!
Drives: 2016 Scion FRS
Loosen the bolts on the FP and OP flanges and remove the bolts on the solid hanger near the gearbox. Spray all the nuts down the night before and just before with PB Blaster you'll be fine. have a dab of grease on hand to help stick the gaskets up to the block.
Use a new Grimmspeed gasket every time you put the header back on. You don't have to uninstall the entire exhaust, but it has to be loose to wriggle the header off. |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
