Spacers 20mm only rear, is a good idea?
Hello all,
I bought two pairs of spacers for my BRZ (15 and 20mm), but in the front I can't mount 15mm without removing material from the wheel because the bolts are touching with it, and I don't want to do that (is stock wheel) What do you think about leaving only rear spacers (20mm) in terms of compromising the original geometry? Could it be counter productive? I would like to avoid buying 20mm spacers front because in my opinion is too much for the front Thank you very much in advance Enviado desde mi Pixel 3 mediante Tapatalk |
Drives: 2017 BRZ w/PP
when you said remove material i pictured this [ame]https://www.youtube.com/watch?v=9c50AoeJviI[/ame] also do you have extended lugs? i assume so
| The Following User Says Thank You to Breadman For This Useful Post: | wparsons (10-22-2019) |
ProCrastinationConsultant
what is your goal with the spacers?
| The Following User Says Thank You to soundman98 For This Useful Post: | wparsons (10-22-2019) |
#4 | |
I don't have extended lugs, but it will touch anyway with the wheel when using 15mm spacers My goal with the spacers is only aesthetics Enviado desde mi Pixel 3 mediante Tapatalk |
nothing i couldn't fix with a grinder to the lugs
| The Following User Says Thank You to soundman98 For This Useful Post: | RToyo86 (10-19-2019) |
Dismember
Drives: 2013 Red Scion FR-S
More planted in the back. More likely to understeer. Possibly some other side effects, but nothing big. Probably nothing you would notice unless you're a 10/10ths guy at the track.
Country Boy 4 Life
You have two options:
1. Cut (shave) the studs shorter. It is how guys are using thin bolt on spacers and wheels without pockets. I cut 10 in an hour with a hacksaw; my arm was tired. This is the cheapest option. 2. Install the 20mm spacers on front and get 25mm spacers for the rear. You could also go 20mm all around. This is the simplest option. Option B: Have a beer! Sell the spacers!
I LIKE TIRES! |
| The Following 5 Users Say Thank You to Leonardo For This Useful Post: | Clutch Dog (10-19-2019), DAEMANO (10-20-2019), RToyo86 (10-19-2019), sato (10-22-2019), soundman98 (10-19-2019) |
yall are sketch as fuck. just run some widebois
| The Following User Says Thank You to Breadman For This Useful Post: | Tristor (10-20-2019) |
#9 | |
i believe in working smarter, not harder, especially on the weekend. $15. https://www.harborfreight.com/corded...der-69645.html i work hard enough the rest of the week, i don't believe in difficult sweat inducing labor on the weekends.
| The Following User Says Thank You to soundman98 For This Useful Post: | Leonardo (10-19-2019) |
#10 |
Depends on the brand of rims and parts used.
Is it the studs or the nuts? 15mm spacers fit fine on my 86 with Enkei RPF-1 with low profile nuts. This is what your 6" ruler is for.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | soundman98 (10-19-2019) |
#11 |
What's the minimum thickness of the spacers for studs flushness? My wheels are almost flat on the hub...
#12 |
Drives: 2017 Subaru BRZ Limited
This thread explains a lot about why people think spacers are unsafe, when in fact if done PROPERLY they are perfectly fine even on a race track under hard use.
| The Following User Says Thank You to Tristor For This Useful Post: | wparsons (10-22-2019) |
#13 | ||||
First, thank you all for answering
I am not comfortable by grinding the studs...I could do it wrong and screw up the thread or something, I have never worked on steel 20 mm spacers in front looks to me too much, thatīs why I am plannig to leave it like that, If there is not problem for the car dynamics Quote:
Yes... itīs a change in the suspension geometry, thatīs why I want to be sure. What do you mean by properly? |
| The Following User Says Thank You to J95 For This Useful Post: | Leonardo (10-22-2019) |
#14 |
Widening the rear track will definitely add some understeer, but you might not notice it depending on your skill level and the rest of your setup.
| The Following User Says Thank You to wparsons For This Useful Post: | sato (10-22-2019) |
| WTB: Spacers- 25mm rear, 20mm front | Just Drive | Canada Classifieds | 1 | 06-26-2017 11:00 AM |
| FS: 4X Ichiba hubcentric 5x100 bolt on spacers front 20mm and rear 30mm for BRZ/FRS | Mint86 | Brakes, Suspension, Chassis | 7 | 07-08-2015 08:05 PM |
| Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels | Calin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 60 | 12-12-2014 02:25 PM |
| *UPDATE* I got Eibach springs and spacers. Is 25mm not good enough for the rear? | trinxified | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 08-22-2014 02:57 AM |
