Old 10-19-2019, 08:45 AM   #1
J95
J95's Avatar
Spacers 20mm only rear, is a good idea?
Hello all,
I bought two pairs of spacers for my BRZ (15 and 20mm), but in the front I can't mount 15mm without removing material from the wheel because the bolts are touching with it, and I don't want to do that (is stock wheel)
What do you think about leaving only rear spacers (20mm) in terms of compromising the original geometry?
Could it be counter productive?
I would like to avoid buying 20mm spacers front because in my opinion is too much for the front
Thank you very much in advance
Enviado desde mi Pixel 3 mediante Tapatalk
J95 is offline   Reply With Quote
Old 10-19-2019, 09:55 AM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
when you said remove material i pictured this [ame]https://www.youtube.com/watch?v=9c50AoeJviI[/ame] also do you have extended lugs? i assume so
The Following User Says Thank You to Breadman For This Useful Post:
wparsons (10-22-2019)
Old 10-19-2019, 12:17 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
what is your goal with the spacers?
Old 10-19-2019, 12:29 PM   #4
J95
J95's Avatar
No haha, the problem is this one:
I don't have extended lugs, but it will touch anyway with the wheel when using 15mm spacers
My goal with the spacers is only aesthetics
Old 10-19-2019, 12:38 PM   #5
soundman98
soundman98's Avatar
nothing i couldn't fix with a grinder to the lugs
RToyo86 (10-19-2019)
Old 10-19-2019, 12:42 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
More planted in the back. More likely to understeer. Possibly some other side effects, but nothing big. Probably nothing you would notice unless you're a 10/10ths guy at the track.
Old 10-19-2019, 12:46 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You have two options:
1. Cut (shave) the studs shorter. It is how guys are using thin bolt on spacers and wheels without pockets. I cut 10 in an hour with a hacksaw; my arm was tired. This is the cheapest option.
2. Install the 20mm spacers on front and get 25mm spacers for the rear. You could also go 20mm all around. This is the simplest option.
Option B: Have a beer! Sell the spacers!
I LIKE TIRES!
The Following 5 Users Say Thank You to Leonardo For This Useful Post:
Clutch Dog (10-19-2019), DAEMANO (10-20-2019), RToyo86 (10-19-2019), sato (10-22-2019), soundman98 (10-19-2019)
Old 10-19-2019, 03:26 PM   #8
Breadman
Breadman's Avatar
yall are sketch as fuck. just run some widebois
Tristor (10-20-2019)
Old 10-19-2019, 03:47 PM   #9
soundman98
soundman98's Avatar
lol, you did all that with a hack saw?!?
i believe in working smarter, not harder, especially on the weekend.
$15.
https://www.harborfreight.com/corded...der-69645.html
i work hard enough the rest of the week, i don't believe in difficult sweat inducing labor on the weekends.
Leonardo (10-19-2019)
Old 10-19-2019, 06:33 PM   #10
86MLR
86MLR's Avatar
Depends on the brand of rims and parts used.
Is it the studs or the nuts?
15mm spacers fit fine on my 86 with Enkei RPF-1 with low profile nuts.
This is what your 6" ruler is for.
The Following User Says Thank You to 86MLR For This Useful Post:
Old 10-20-2019, 04:09 AM   #11
gpvecchi
gpvecchi's Avatar
What's the minimum thickness of the spacers for studs flushness? My wheels are almost flat on the hub...
Old 10-20-2019, 05:49 PM   #12
Tristor
Tristor's Avatar
This thread explains a lot about why people think spacers are unsafe, when in fact if done PROPERLY they are perfectly fine even on a race track under hard use.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Old 10-22-2019, 06:44 AM   #13
J95
J95's Avatar
First, thank you all for answering
I am beginner in tracks but I enjoy a lot, I dont think I would notice, but honestly I would like to avoid understeer
$15.
I am not comfortable by grinding the studs...I could do it wrong and screw up the thread or something, I have never worked on steel
20 mm spacers in front looks to me too much, thatīs why I am plannig to leave it like that, If there is not problem for the car dynamics
Yes... itīs a change in the suspension geometry, thatīs why I want to be sure. What do you mean by properly?
The Following User Says Thank You to J95 For This Useful Post:
Leonardo (10-22-2019)
Old 10-22-2019, 09:30 AM   #14
wparsons
wparsons's Avatar
Widening the rear track will definitely add some understeer, but you might not notice it depending on your skill level and the rest of your setup.
flickr
sato (10-22-2019)
WTB: Spacers- 25mm rear, 20mm front Just Drive Canada Classifieds 1 06-26-2017 11:00 AM
FS: 4X Ichiba hubcentric 5x100 bolt on spacers front 20mm and rear 30mm for BRZ/FRS Mint86 Brakes, Suspension, Chassis 7 07-08-2015 08:05 PM
Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels Calin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 12-12-2014 02:25 PM
*UPDATE* I got Eibach springs and spacers. Is 25mm not good enough for the rear? trinxified Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-22-2014 02:57 AM
