Old 08-11-2014, 03:58 AM   #1
trinxified
Drives: Subaru BRZ Aozora Edition
Question *UPDATE* I got Eibach springs and spacers. Is 25mm not good enough for the rear?
I got 2015 BRZ Series.Blue and looking to just use the stock wheels on them for my setup.
What size spacers should I get to make it a bit more flush? I'm assuming 20mm front, 25mm rear? Any particular brands, types, etc.?
This is lowered with Eibach Pro-Kit.
EDIT: Update guys... I got the Eibach pro-kit springs and pro-spacers on now...
20mm at front, 25mm at rear. But it still looks like the rear is tucked in more than the front? Is this normal? Should I have gotten 30mm instead for the rear?
trinxified is offline   Reply With Quote
Old 08-11-2014, 04:50 PM   #2
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
They are 17x7 +48 I believe which is the same as the stock wheels for all other cars.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 08-11-2014, 05:47 PM   #3
srizzors25
Daedalus Moto
srizzors25's Avatar
https://www.japanparts.com/parts/detail/40551
Should be identical to the oem brz/frs wheel just different design/color
Old 08-11-2014, 06:13 PM   #4
trinxified
Oh nice it's a bit wider than the OEM, 17x7.5 +48
Old 08-11-2014, 06:19 PM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
The ones that are on teh NA blues are 17x7
-Jack Burton
Old 08-11-2014, 06:26 PM   #6
trinxified
Oh okay thanks for clarifying. The same then.
Old 08-11-2014, 06:33 PM   #7
srizzors25
Daedalus Moto
srizzors25's Avatar
Ah my bad must have grabbed the wrong one there. Unless they labeled it wrong
Old 08-16-2014, 05:47 PM   #8
trinxified
Hey guys... I decided to get Eibach spacers, 20mm front, 25mm rear...
Good decision?
Old 08-21-2014, 03:08 PM   #9
trinxified
Old 08-21-2014, 04:13 PM   #10
DAEMANO
Time Traveller
25 or 30 is so close in looks it's really splitting hairs. I had 25's in the rear of mine for a long time and loved it. Be happy, your Blue will look better than most others.
Old 08-21-2014, 04:16 PM   #11
trinxified
Or maybe getting 15mms instead for the front...
Old 08-21-2014, 04:21 PM   #12
teamturbo
teamturbo's Avatar
15 front, 20 rear gives a really clean look.
teamturbo is offline   Reply With Quote
Old 08-22-2014, 02:00 AM   #13
trinxified
I'm also thinking perhaps I need alignment... That's probably throwing some off too.
Old 08-22-2014, 02:16 AM   #14
DAEMANO
Time Traveller
The rear suspension gets more negative camber the more you lower the car. This causes the rear to "tuck" more. This is generally desirable. However, if you really don't want any negative camber in the rear, you can "fix" it by adding adjustable rear lower control arms.
2015 Series.Blue BRZ fungizmos BRZ First-Gen (2012+) — General Topics 572 01-27-2016 02:54 AM
Series Blue won't come to New England? Turbowned BRZ First-Gen (2012+) — General Topics 15 08-20-2014 06:48 PM
FS - 2015 BRZ Series.Blue STI wheels RIP.S2000 Wheels and Tires 9 08-03-2014 07:36 PM
Decoding BRZ Series Blue VIN Jimmy45brz BRZ First-Gen (2012+) — General Topics 4 07-20-2014 12:11 AM
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
