Old 08-22-2019, 12:20 PM   #1
H_K
Drives: '13 Scion fr-s
O2 sensor removal without an O2 socket?
Just wondering, would using a regular wrench be alright when removing the o2 sensor during a header install? Not sure if buying the o2 sensor is really necessary.
H_K is offline   Reply With Quote
Old 08-22-2019, 12:23 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The problem with an exhaust component is that they are pretty much seized by the heat. A socket is your best bet to avoid stripping the O2 sensor and getting into bigger, more expensive problems.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
H_K (08-22-2019), wparsons (08-23-2019)
Old 08-22-2019, 12:29 PM   #3
H_K
Ok. It's a tool that I think I'll only use the one time so I was hoping to avoid it. I think maybe I'll need it after all but was on the fence about it.
I plan to do the header install with hand tools but now I'm scared I won't be able to muscle off all the bolts on the header if they're all going to be seized... Any advice?
Old 08-22-2019, 12:41 PM   #4
SpankNapkin
Drives: 2013 Subaru BRZ
I did this job two weeks ago on my 2013, the exhaust bolts weren't terrible, just make sure you have a variety of short and long wrenches, as well as a variety of shallow and deep sockets. If your socket set does not have an extension and a swivel/ujoint you would be wise to get these before getting under your car.
The show stopper I ran into was the rear O2 was completely, utterly seized onto my OEM manifold. I had to install the plug into the bung my new header, and run without for a week until I ordered a new one off rockauto. I was able to disable some of the rear o2 compensations via my OFT/romraider so that I could get by, but this isn't a long term solution. I would suggest sourcing both rear and front O2's that you could pick up nearby at a moments notice if you get stuck in the middle of the job.
SpankNapkin is offline   Reply With Quote
The Following User Says Thank You to SpankNapkin For This Useful Post:
H_K (08-22-2019)
Old 08-22-2019, 12:41 PM   #5
MX-5RACER
Drives: 1999 Miata
Not sure about the plug on these cars, but with my Miata I am able to get the plug through the box end of a 7/8" combination wrench. 7/8" is the O2 size, using a quality combination wrench I have been able to remove them when my O2 wrench bends too much.
Make sure you get a few of the little anti-seize packets at the parts store. Apply this to the threads ONLY, before you re-install the sensor.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
The Following User Says Thank You to MX-5RACER For This Useful Post:
H_K (08-22-2019)
Old 08-22-2019, 02:36 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Flare nut wrenches work great too and can be used in other situations, if you don't want to buy a single/whole socket set for one job.
Also, buy 22 millimeter for the FRS. Don't buy the "universal" or 7/8: they are just slightly large and you run a high risk of rounding off the sides
As far as getting another O2 sensor, it doesn't hurt to be prepared. Get a generic replacement at an auto parts store or exact replacement at the dealer in case. At worst, you lose some shoe leather and a restocking fee.
As others have mentioned, the risk is there that the O2 sensor is seized on and the threads simply get mangled when you pull the sensor off. Mine took some elbow grease to get off, but luckily the threads were good.
That being said, it's worth getting an O2 sensor thread chaser as well.
EndlessAzure is offline   Reply With Quote
Old 08-22-2019, 02:53 PM   #7
Sportsguy83
Drives: Limited BRZ
Unless your car is rusted up because of salt, you shouldn't worry much.
You could rent the O2 socket from advanced auto parts, (at least here in the states) for free.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Lantanafrs2 (08-22-2019)
Old 08-22-2019, 09:37 PM   #8
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Liquid wrench and a crows foot bro
mswbrz is offline   Reply With Quote
The Following User Says Thank You to mswbrz For This Useful Post:
Sportsguy83 (08-23-2019)
Old 08-22-2019, 10:06 PM   #9
ermax
ermax's Avatar
Dude they cost like three pennies. Just go buy one. Also, make sure the manifold is completely cold (like over night cold) before touching it or it will eat itself and force you to buy another cheap tool (thread tap) and new sensor.
Old 08-23-2019, 02:30 AM   #10
Turdinator
Señor Member
Turdinator's Avatar
I used and adjustable wrench for mine. But I do live in Australia where the roads are never salted and a non-stainless exhaust will easily live 10 years without issue...
1974 TA22 Celica
2013 86 GT
Old 08-23-2019, 10:01 AM   #11
wparsons
wparsons's Avatar
He's from Canada, so I'd bet it's going to be pretty nasty.
flickr
Old 08-23-2019, 04:07 PM   #12
Alpha86
Drives: 2013 Firestorm Red FRS
My stock manifold was pretty rust free, i managed to get it off with an adjustable wrench ¯\_(ツ)_/¯
Its a lot easier to work on if you unplug them from the top, pull the header and unbolt the sensors when its off the car.
Alpha86 is offline   Reply With Quote
The Following User Says Thank You to Alpha86 For This Useful Post:
wparsons (08-26-2019)
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Socket Set MrMista Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-28-2013 03:21 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 09:30 PM
