Old 07-31-2019, 08:26 AM   #1
killy
Drives: BRZ Limited
Oil operating temperature and oil cooling
I have read in several threads that the oil temperature which is shown trough the OBD 2 port, being measured at the sandwich plate, is in fact 5 to 10° hotter than the actual temperature in all the engine and / or at the sump.
Does anybody know more about this? is it true / false / in between?
That could generate an issue because, after installing an hks oil cooler with a thermostatic sandwich plate set to 80°C, now the oil temp (which I read trough the OBD) is alwyas around 79 -- 82° C during normal road driving or highway..
If the above story is true it means than that the oil never reaches operating temp? could this create some issues?
I often track my car but i would not want to go around doing "normal" driving and damage the engine because it runs 70% of the time at a sub optimal oil temp. Also keep in mind that now ambient is 30°.
during winter i was going to cover the radiator...but i am having doubts that I might have to do it already.
any opinions?
killy is offline   Reply With Quote
Old 07-31-2019, 08:41 AM   #2
86MLR
86MLR's Avatar
Grab a infrared temp gun.
Super handy at the track to check your tyres as well.
On my old Skyline I needed to block off the air to oil cooler with a blanking plate for street use during the colder months.
I would remove it for the track, I forgot to block it off one time coming home from Wakefield Park, IIRC my oil temp on the hwy was at 60°c, yes, when I saw that I stopped and put the blanking plate back on.
I like my oil somewhere between 100-115°c, easier said than done though.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 07-31-2019, 10:32 AM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Over cooling is why I run the Forester oil cooler. Or if I change it, I'd go for the Jackson Racing dual radiator oil cooler.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
jcw99 (07-31-2019)
2qt Accusump, -10 AN line, fittings, bracket, remote operating cable Joesurf79 Engine, Exhaust, Bolt-Ons 29 02-24-2023 01:04 PM
Ideal engine oil operating temp range SirBrass Engine, Exhaust, Transmission 36 05-31-2016 03:22 PM
Engine oil standard operating temperature brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-22-2015 01:12 AM
Power Windows Not Operating Andrizzle Issues | Warranty | Recalls / TSB 13 03-04-2014 10:53 PM
How to tell Engine's Operating Temp? tez2013 Tracking / Autocross / HPDE / Drifting 9 06-03-2013 01:33 AM
