Drives: 2013 Firestorm FR-S
Engine oil standard operating temperature
I've looked through the manuals but I can't find the recommend max operating temps. Trying to understand when I should be concerned when tracking the car.
Thanks
2013 Firestorm FR-S, MTX, build date 1/13.
Red wine
Drives: Subaru BRZ(R.I.P)
When the engine oil temp climbs up to 100 degree celcius, you start to lose power.
Source http://blog.perrinperformance.com/pe...-s-oil-cooler/
Drives: 2013 FR-S Blue MT
I believe normal is between 90-100C. I would start worrying if it gets above 120C and seriously consider getting an oil cooler.
Drives: 13 White MT FR-S
mine usually sits around 200F depending on outside temps, and revs. but 200F +-10F
#5 | |
Site Moderator
Drives: Stuff
On track I'd guess the stock car is 270-300 all day long based on similar cars.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
you are correct
Drives: None
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Drives: 2014 FR-S 6MT Monogram Series
I live in socal and average daily driving from home to work or back home its anywhere from 190-210F. On track that Ive tracked 3 times average is 240-250F
#10 |
Drives: BRZ DGM Limited
Op, if I can borrow your thread for a second....can anyone direct me to a how-to for installing oil temp/pressure gauge??
#11 |
Drives: Hot Lava 86 MT
Same question as above. On the block there is one space for a sensor. other sensor will go below the oil filter in a sandwich. So which sensor on which position?
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
#12 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
According to dash command my avg dd temp is 170f and 190f on the track. I have an oil cooler, upgraded radiator and all the goodies that come with
#13 | |
this summarizes it pretty well [ame="https://www.youtube.com/watch?feature=player_embedded&v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame] Data from video You want to keep above about 40psi at high rpm so if your running 0w20 once temps get to 225F you starting to get into that low 40psi range. STREET TEMPS 0W20 Redline 0w20 Redline 185F @ 800RPM 10PSI Oil Pressure 0w20 Redline 185F @ 2000RPM 35PSI Oil Pressure 0w20 Redline 185F @ 4000RPM 54PSI Oil Pressure 0w20 Redline 185F @ 7000RPM 65PSI Oil Pressure 10W30 Redline 10w30 Redline 185F @ 800RPM 19PSI Oil Pressure 10w30 Redline 185F @ 2000RPM 51PSI Oil Pressure 10w30 Redline 185F @ 4000RPM 65PSI Oil Pressure 10w30 Redline 185F @ 7000RPM 83PSI Oil Pressure 10W40 Redline 10w40 Redline 185F @ 800RPM 25PSI Oil Pressure 10w40 Redline 185F @ 2000RPM 64PSI Oil Pressure 10w40 Redline 185F @ 4000RPM 78PSI Oil Pressure 10w40 Redline 185F @ 7000RPM 91PSI Oil Pressure TRACK TEMPS AFTER 9 LAPS @ 1 Minute 15 Seconds Per Lap 0W20 Redline 0w20 Redline 225F @ 800RPM 7PSI Oil Pressure 0w20 Redline 225F @ 2000RPM 30PSI Oil Pressure 0w20 Redline 225F @ 4000RPM 48PSI Oil Pressure 0w20 Redline 225F @ 7000RPM 43PSI Oil Pressure 10W30 Redline 10w30 Redline 245F @ 800RPM 7PSI Oil Pressure 10w30 Redline 245F @ 2000RPM 35PSI Oil Pressure 10w30 Redline 245F @ 4000RPM 52PSI Oil Pressure 10w30 Redline 245F @ 7000RPM 46PSI Oil Pressure 10W40 Redline (12 Laps) 10w40 Redline 265F @ 800RPM 8PSI Oil Pressure 10w40 Redline 265F @ 2000RPM 31PSI Oil Pressure 10w40 Redline 265F @ 4000RPM 55PSI Oil Pressure 10w40 Redline 265F @ 7000RPM 45PSI Oil Pressure |
#14 |
Drives: RX-7 / BRZ
I easily could hit 270F (100% stock) after a day of tracking in 80F weather. This was with 10min~avg sessions with 15min cooldowns between drives... rinse and repeat as many time until sun-down.
The car will start to pull timing after the oil hits 220F. Before tracking her, go switch to a heavier oil. 0w20 is fine for daily grinds but, it loose's it's pressure when it gets past 240F.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| Temperature not reading below 0 | BrewCity-FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-22-2013 10:05 AM |
| BRZ temperature display malfunction | percyng | CANADA | 7 | 10-24-2012 09:31 PM |
| Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) — General Topics | 29 | 09-20-2012 01:19 PM |
| Disp Temperature not accurate | marinjim | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 08-22-2012 08:16 AM |
| Engine temperature | Skye | Issues | Warranty | Recalls / TSB | 5 | 08-09-2012 10:33 PM |
