Old 07-23-2019, 06:19 PM   #1
Suparu
Drives: 2013 BRZ Limited
Replacing mushroom filter for conical?
I’ve had the SBD kit for 3 years and the inside of my intake pipe looks awful. So I want to change this mushroom filter setup for something like a K&N cone filter.
The only post I found on someone doing this with a turbo kit had problems with the rubber melting and tearing where it connects to the intake tube, from the K&N’s rubber not being able to withstand the heat under the hood. He said it “couldn't stand up to the heat and the weight of the filter hanging of the flange without any other support.”
Has anyone had better luck replacing their mushroom filter for a cone filter? If so, what size and can you post pics? There’s hardly any room for a cone filter unfortunately and I don’t want to delete my washer fluid bottle cuz this is my DD.
Suparu is offline   Reply With Quote
Old 07-23-2019, 08:31 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Literally any thing would work.
If the inside of your pipe is horrible, you are neglecting your filter maintenance.
If you don't want to spend any time cleaning filters go back to stock, buy any performance drop in filter. You'll have the same power gains.
Old 07-23-2019, 09:23 PM   #3
Suparu
I don’t neglect filter maintenance, these mushroom filters just suck. They’re good at keeping rocks from hitting the condenser but that’s it. Can’t do a drop-in, I have a front-mount turbo. The stock air box is long gone. So it’s mushroom vs conical.
Old 07-23-2019, 09:36 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Conical will work well, but mind the length of the filter. Some are very long and will bump the washer fluid reservoir.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Suparu (07-23-2019)
Old 07-26-2019, 10:36 AM   #5
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
OP, use a K&N RU-3120 filter. I run this on my SBD turbo kit and it works flawlessly. It is a low profile filter so you will be able to clear any oil cooler lines, if equipped.
drew_kar is offline   Reply With Quote
Old 07-29-2019, 11:08 AM   #6
Amputechture
Drives: 2014 BRZ
I have a V1 JDL setup, so my turbo location is fairly close to yours. I have a VTA catch can/PCV delete so I simply put the filter directly onto the compressor inlet. I use an AEM filter, the largest that will possibly fit....pretty much just enough room to be able to remove it for cleaning.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 07-29-2019, 11:22 AM   #7
Amputechture
Drives: 2014 BRZ
https://ibb.co/MPWx9FJ
Another OEM Armrest Install (Using Mushroom Nuts) rubbercow Cosmetic Modification (Interior/Exterior/Lighting) 1 10-31-2016 09:49 PM
Conical lug nut with extended thread question... dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-09-2015 07:50 PM
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Need Help on Replacing Stock Air Filter Sookainian Engine, Exhaust, Transmission 5 03-15-2014 09:47 PM
cons of mushroom filter? ft86me Forced Induction 13 10-22-2013 02:37 AM
