Old 02-09-2015, 07:35 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Conical lug nut with extended thread question...
On my set of Speedline Corse wheels, they came with conical sealed lug nuts with the extended thread.
Would it be safe to use conical lug nuts that don't have the extended thread? I don't feel like blowing $100 to find out. Tried Google, didn't find anything. Really difficult to find good quality leg nuts with out size and an extended thread.
For those confused, in the image below. 2nd from top to the left is what i have.
Old 02-09-2015, 07:38 PM   #2
jvincent
jvincent's Avatar
Double check the diameter of the wheel lug nuts holes. The ET nuts may not fit through.
Old 02-09-2015, 07:50 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Only useful if the extended thread portion fits inside the wheel. Usually you'd only need something like this if it was a wheel drilled for 14mm wheel studs but you're using 12mm wheel studs.
It's quite common with Euro-spec wheels designed for lug bolts. I'm guessing the wheels were meant for a VW originally.
-alex
Question on my FS thread being locked mav1178 Site Announcements / Questions / Issues 3 09-30-2014 09:11 PM
OZ Ultraleggera - ball or conical seat nuts? Fizz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-11-2014 09:10 AM
Where should we go to buy extended warranty? qqzj BRZ First-Gen (2012+) — General Topics 8 02-25-2014 12:43 PM
Extended Warranty kevinnivek8877 BRZ First-Gen (2012+) — General Topics 30 06-14-2012 05:00 PM
Extended Warranty? FoxtrotRomeo-Sierra Scion FR-S / Toyota 86 GT86 General Forum 4 05-31-2012 01:02 PM
