Old 10-20-2013, 11:42 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
cons of mushroom filter?
what are the cons of a mushroom filter on a the front of the vortech unit? warm air? what else? thanks guys.
ft86me is offline   Reply With Quote
Old 10-21-2013, 02:37 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Surely the intercooler will reduce IATs more than having a filter in the bay will increase it? I'd love to see some real testing comparing air temps pre and post intercooler with CAIs and SRIs. If you look at any high powered cars like Supras and Skylines, they usually have their filters sat in the engine bay. I doubt that the ambient temperatures will have nearly as much impact as the compression on temperature.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-21-2013, 02:39 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
I see what you're saying. I see the same thing too. That's why I'm curious. Plus it'd free up lots of room for me in the engine bay. Hoping we can get further input. Thanks for the input!!! Appreciate it !
Old 10-21-2013, 02:57 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
I think a secondary question is how well does the intercooler cool? I've lots of calculations about heat gain by compressing air, but does the intercooler drop temperature by a constant xC in any given circumstance or would higher temperatures be cooled more efficiently?
For example (ambient of 10C):
a) In: 60C Out: 30C and In: 70C Out: 40C
b) In: 60C Out: 30C and In: 70C Out: 34C
Alot of this can only be tested on the road due to air travelling over the intercooler. I'm interested in the same findings as I tested the stock intake for heat soak, but I'll be looking to remove the stock CAI when I fit my Sprintex charger later this year and will be interested in how much of an impact on IATs it makes post charger.
Have you got any way of measuring the IATs? Where is the sensor on the Vortech?
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-21-2013, 02:59 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
You know I'm not even sure. You're far more advanced than I am w this stuff
Old 10-21-2013, 03:58 AM   #6
OrbitalEllipses
Drives: Attitude
The real question is "if intake temp is A and cold pipe temp is B...if intake temp becomes C, does cold pipe temp still equal B or does it become D?" Do they vary accordingly or is your intercooler so efficient as too always cool to B?
With further reading, it would appear that's what you're talking about. It would stand to very, very basically argue that higher intake temp equals higher output temp; the real problem then becomes "is the difference in output temperatures significant to performance versus the benefits of a higher intake temp?"
Old 10-21-2013, 09:25 AM   #7
mrk1
Drives: Sterling BRZ Ltd
People love to harp on "hot air intakes" if you post a pic of one. I really don't think its as huge a deal as some people make it out to be. I personally am a fan of an air box that get feed from an outside source like the factory intake. Often the complex route to get the filter into cold air makes it counter productive. Id rather have a hot air intake then a cold water intake.
Like it was mentioned before there are plenty of very high end very high hp cars that have the filter right in the engine bay so it cant be that bad.
How and where the car is used also needs to be considered. Race cars are always moving at high speeds with air flowing in and around the engine bay. A street car spends time heat soaking while waiting in traffic and even when they get going its not that fast on a normal road. I didn't go over 45mph on my commute this morning.
Im sure someone will post a dyno chart of some car with a short ram vs cold air but thats on a dyno not real world use.
And thats my morning coffee .02 for the day
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-21-2013, 09:32 AM   #8
DJCarbine
Thupercharged
DJCarbine's Avatar
I would be more concerned about filtration efficiency TBH
2013 FRS
Vortech V3 11psi
Old 10-21-2013, 09:35 AM   #9
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
One problem with mushroom intakes like the HKS Suction filters is that they'll keep cats and dogs out of your intake but not much else. Saw tons of dust in my Evo's intake when I ran one on my car.
They'll flow more, but just a small step up from running filterless IMHO. You'll also probably want to tune the ECU carefully for that filter as we found that they lean the engine out sunstantially, which could lead to detonation.
Depends what your priorities are though. For maximum flow the Perrin (or was it FA20club?) filter + in-bumper cold air tube setup looks good.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 10-21-2013, 09:38 AM   #10
u/Josh
Drives: GBS Limited 6MT
Example B is correct. Heat transfer is driven by temperature differences, so the greater the difference between the hot air in your intercooler and the ambient air, the more heat transfer there will be.
u/Josh is offline   Reply With Quote
Old 10-21-2013, 09:48 AM   #11
ft86me
ft86me's Avatar
Drives: 2013 FRS
Wow so much great input !!! Thanks guys. Hmm what to do
Old 10-21-2013, 10:01 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This. If you want to make your own intake or just run a filter on a pipe, that is fine, but go with a good filter. K&N has many different shapes and sizes available if size is a major concern.
Old 10-21-2013, 10:30 AM   #13
nonicname returns
Drives: 4 wheels
aftermarket Air filters are junk:
[ame="http://www.youtube.com/watch?v=gCi2yo4UqPI"]Cold Air Intakes Mythbusted - YouTube[/ame]
nonicname returns is offline   Reply With Quote
Old 10-22-2013, 02:37 AM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
I think you meant the benefits of a higher flowing filter/system?
This sort of question have too many variables that realistically I think it will matter little when you really need it, when you're driving at speed. Heat soak is an issue when stationary or in slow traffic, but then the intercooler will be inefficient at those speeds and the compression of air will cause the air temperature to rise, whether CAI or not it will be above ambient anyway .
.: Stealth 86 :.
Kodename 47 DJ:
cons of buying online? chickdigger802 BRZ First-Gen (2012+) — General Topics 35 09-03-2013 10:42 PM
Car Wrap / Foil Wrap : Pros and Cons? LeBryan Cosmetic Modification (Interior/Exterior/Lighting) 0 06-25-2013 09:13 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
What are the Pros and Cons of switching to a bigger set of Brakes? STi88 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 08-06-2012 02:50 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
