Old 07-02-2019, 10:16 PM   #1
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
replacement SPACER lug nuts
Anyone know where I can find replacement lug nuts for my
Eibach spacers. I successfully managed to strip several lugs.
FML!!! anyway, No luck at Auto zone, Advance auto parts, NAPA or
anywhere local
it has to be 10 17mm lug nuts short head and 10 19mm
"My teacher tells me real beauty is on the inside." "That's just something ugly people say."
xenarc is offline   Reply With Quote
Old 07-02-2019, 10:19 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Just buy a new spacer.
Problem solved.
Actually I'll prefer you burn that pos of a car, and go out and buy a new Civic SI.
You will not regret it.
The Following User Says Thank You to Mr.ac For This Useful Post:
Tristor (07-03-2019)
Old 07-03-2019, 09:40 AM   #3
Chuckls
Moutain Runner
Problem solved.
I bet you're a joy to be around at parties.
Chuckls is offline   Reply With Quote
Old 07-03-2019, 04:06 PM   #4
xenarc
xenarc's Avatar
Alexa had a better answer than Mr.ac
Old 07-03-2019, 10:22 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
I only attend circle jerk parties. Those are awesome. I'll send anyone an invite for the next one.
Dude, assuming you have aluminum spacers and the you already stripped out the studs I could call your spacer already fucked. it's already weaked when you stripped it out.
But what ever it's your car. Your money.
Also... you could have bought those longer studs and simply grind them a bit down. If you don't own a grinder any hardware store would have done that for you.
But. Maybe as Alexa next time. Hopefully I'll program it to razzel dazzel you if you ask it again.
Rice hard bro. Jk. I'm fooling with you.
Old 07-04-2019, 03:13 PM   #6
wparsons
wparsons's Avatar
Aluminum spacers still have steel studs... see below, but even if the stud was stripped, it wouldn't weaken the spacer at all.
If you actually read what he posted, he is looking for LUGS, not STUDS.
anywhere local
flickr
Old 07-04-2019, 04:51 PM   #7
xenarc
xenarc's Avatar
@ Mr.ac, all the studs are fine. it was only 3 lug nuts that were rounded off but I still want to replace all 20 of them. I had to go to my friends shop to remove them using those stripped lug nut remover sockets and the came off so easy.
I just wanted to know if anyone here knew a website that sells short head lugs
designed for spacers.
Replacement nuts for Eibach spacers treminaor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-16-2017 04:39 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Brakes, Suspension, Chassis 1 10-05-2016 12:48 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Wheels and Tires 0 10-01-2016 09:50 PM
Wheel Spacer Lug Nut Replacement? Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-12-2016 03:06 AM
help with the 20mm spacer nuts Vten Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-01-2013 01:35 AM
