Old 11-18-2013, 10:34 PM   #1
Vten
Drives: Too heavy
help with the 20mm spacer nuts
hi guys,
I bought the 20/25mm spacer of the vendor here.
I have a problem with the nuts that secure the bolts is actually doesn't flush flat with the spacer. the wheels Im going to use has the pocket back next to the lugs holes , but for some reason the nuts doesn't fit the pocket.
so I was wondering if I want to keep the wheels, I need to get a shorter nuts (12x1.25 acorn style nuts) or I can go with the 25mm, but I don't really want to go with the 25mm up front ...the tires poke too much.
any input would be greatly appreciated.
thanks
guys
Vten is offline   Reply With Quote
Old 11-18-2013, 10:41 PM   #2
Tiremonkey0824
Drives: 2013 Argento 6mt
I would personally very carefully bore the little pockets behind the wheel out with a die grinder and a carbide bit. Just need to be careful enough to not to take too much material off and compromise the rigidity of the wheel.
Tiremonkey0824 is offline   Reply With Quote
Old 11-18-2013, 10:52 PM   #3
Vten
Drives: Too heavy
yeah I think I can do that, but if I can get the shorter nut, I think it'll be better and safer too tho .
the one that came with the spacer is about 3mm too long
Old 11-19-2013, 07:02 PM   #4
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
Lol, there's no way for OP to know how much is too much.
OP, there are only two solutions to your problem, the way I see it. One is that you replace all the OEM studs with extended studs, then run a 20mm slip on spacer. Two is that you just run different wheels that have pockets on the back pad to accommodate any nuts/studs that might be poking through.
Redstar is offline   Reply With Quote
Old 11-19-2013, 07:38 PM   #5
Vten
Drives: Too heavy
Or get a thicker spacer ... My 25mm nuts sit flush within the spacer
Got the wheels cheap localy ... Didn't know it'll be a problem before buying them
Old 11-19-2013, 08:47 PM   #6
Redstar
Destroyer of Tires
Redstar's Avatar
Yeah, but you literally said in your first post that you don't want to go with the 25mm spacers up front lol.
Old 11-19-2013, 09:17 PM   #7
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
i wouldnt touch the wheels just get smaller nuts. Cheapest easiest solution , good luck
SLICVIC is offline   Reply With Quote
The Following User Says Thank You to SLICVIC For This Useful Post:
Vten (11-19-2013)
Old 11-19-2013, 11:07 PM   #8
Vten
Drives: Too heavy
any idea where to get one SLICVIC?
Old 11-19-2013, 11:14 PM   #9
White64Goat
Contact vendor you got the spacers from is where I'd start......
Old 11-19-2013, 11:31 PM   #10
Vten
Drives: Too heavy
I did ...no response.
im contacting other vendors too, in case I can buy those nuts from them.
Old 11-20-2013, 12:13 AM   #11
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
You could always dremmel grind the top corners of the nuts down, so they fit in the wheel pockets.
But finding a slightly shorter nut seems like the best solution. If you do, use some thread lock to help hold it in place.
mwjcyber is offline   Reply With Quote
Old 11-20-2013, 12:49 AM   #12
Vten
Drives: Too heavy
I believe so too. the best solution would be finding the shorter nuts ...but couldn't find them anywhere ..
Old 11-20-2013, 12:55 PM   #13
Redstar
Destroyer of Tires
Redstar's Avatar
I don't think it really matters what vendor you buy spacers from, 20mm spacers are 20mm spacers. At least in the pics, it appears that even if the nuts were smaller, the studs would still poke through.
Old 11-20-2013, 12:58 PM   #14
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
@Redstar i think hes saying there are holes that the studs fit into , but the nuts are too big . Im sure you can get at a autosupply- pepboys autozone etc . bring a ruler with you so u know theyll fit for sure. the thread should be 12x1.25 if im not mistaken, do a google search just to be sure.
FS: Ichiba V2 Hubcentric Spacer 20mm, $99.99 shipped. Figo Wheels and Tires 2 11-18-2013 11:27 AM
FS: Ichiba V2 Hubcentric Spacer 20mm, Central Jersey Figo NY / NJ / CT / PA 2 11-16-2013 05:28 PM
FS: Eibach Pro Spacer sets 20mm and 30mm wawro569 Wheels and Tires 4 07-20-2013 01:00 PM
20mm Offset sybrite Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-30-2013 11:21 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
