| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2017 SUBARU BRZ
replacement SPACER lug nuts
Anyone know where I can find replacement lug nuts for my
Eibach spacers. I successfully managed to strip several lugs. FML!!! anyway, No luck at Auto zone, Advance auto parts, NAPA or anywhere local it has to be 10 17mm lug nuts short head and 10 19mm
"My teacher tells me real beauty is on the inside." "That's just something ugly people say." |
#2 |
[insert cool phrase here]
Drives: BRZ Premium
Just buy a new spacer.
Problem solved. Actually I'll prefer you burn that pos of a car, and go out and buy a new Civic SI. You will not regret it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | Tristor (07-03-2019) |
#3 |
Moutain Runner
#4 |
Alexa had a better answer than Mr.ac
#5 |
Drives: BRZ Premium
I only attend circle jerk parties. Those are awesome. I'll send anyone an invite for the next one.
Dude, assuming you have aluminum spacers and the you already stripped out the studs I could call your spacer already fucked. it's already weaked when you stripped it out. But what ever it's your car. Your money. Also... you could have bought those longer studs and simply grind them a bit down. If you don't own a grinder any hardware store would have done that for you. But. Maybe as Alexa next time. Hopefully I'll program it to razzel dazzel you if you ask it again. Rice hard bro. Jk. I'm fooling with you.
#6 | ||
#7 |
@ Mr.ac, all the studs are fine. it was only 3 lug nuts that were rounded off but I still want to replace all 20 of them. I had to go to my friends shop to remove them using those stripped lug nut remover sockets and the came off so easy.
I just wanted to know if anyone here knew a website that sells short head lugs designed for spacers.
| Replacement nuts for Eibach spacers | treminaor | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 08-16-2017 04:39 PM |
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Brakes, Suspension, Chassis | 1 | 10-05-2016 12:48 PM |
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Wheels and Tires | 0 | 10-01-2016 09:50 PM |
| Wheel Spacer Lug Nut Replacement? | Wyattkb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2016 03:06 AM |
| help with the 20mm spacer nuts | Vten | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 12-01-2013 01:35 AM |
