"DGM BRZ"
Drives: 2016 BRZ Limited
Replacement nuts for Eibach spacers
I need to remove my spacers to replace my axle nuts. Tried to remove the spacers a while ago and one of the nuts started stripping because I used a 12pt socket on it, so I stopped. I've since bought all the hardware I need to extract the stripped nut but I need to find a replacement one to use when I put the spacers back on. Anyone know the specific size of the nuts and where I could order them? They're the shallow flat kind that fit flush behind the wheel hub
"DGM BRZ"
anyone?
Drives: 2014 GT86
Have you tried contacting shop you bought at? Googled vendor site/email at contact or support pages?
| The Following User Says Thank You to churchx For This Useful Post: | sato (08-05-2017) |
"DGM BRZ"
Finally found my answer on the packaging. For anyone wondering, the Eibach part number is S2-1-12-25-17-19-O (thats the letter O not a zero). The specs of the nut are M12x1.25x17/17.5 and I found them to buy in the US from a vendor called UltraRev (manufactured by BIMECC-USA). They're pretty pricey, nearly $7 a pop.
| Eibach 20mm Spacers | 2broke4turbo | Wheels and Tires | 1 | 06-18-2016 02:04 PM |
| FS: Eibach 20mm Spacers | Hanakuso | Brakes, Suspension, Chassis | 3 | 04-12-2016 12:29 PM |
| FS: Lug nuts and spacers | jdmblood | Wheels and Tires | 9 | 07-22-2015 11:33 AM |
| SOLD! B2 Auto Designs 20mm/25mm spacers with nuts | Jman1759 | Wheels and Tires | 1 | 08-19-2014 11:10 AM |
| Eibach 20mm spacers just put on! | SMOKETREES | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 12-18-2013 10:13 AM |
