Drives: 2014 Whiteout FRS
Wheel Spacer Lug Nut Replacement?
I purchased a set of B2autodesigns wheel spacers and the lug nuts they came with must have been made of cheap metal. When I went to remove them I stripped them all, had to use a bolt extractor to get them off which in turn destroyed the nuts.
Where can I get better replacement nuts? It seems the ones they gave me are low profile so they sit deep within the spacer. The other ones I had on hand sit too high and do not allow the wheel to sit flush on the spacer. |
Well look like I was able to find b2autodesigns replacement nuts.
http://www.b2autodesigns.com/product...oducts_id=7060 I am just worried they will strip out again. There was a lot of corrosion on the studs when I got them off. Should I just reorder the b2autodesigns ones again? I am afraid to put anti-seize on them after reading how it can change the torque values and cause them to back out. |
| Wheel Spacer Size?? | tonytduc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 11-03-2018 03:36 AM |
| Custom wheel spacer (6mm) | Fizz | Australia Classifieds | 0 | 05-21-2014 02:00 AM |
| 3mm wheel spacer | vroom4 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-16-2014 12:36 AM |
| Wheel Spacer | tonytduc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-06-2013 01:44 AM |
| wheel spacer to 5x114 | derka-derka | AUSTRALIA | 12 | 07-02-2012 11:27 PM |
