Drives: 2016 BRZ
What's actually holding the suspension together when you use an OEM crash bolt?
So i had crash bolts installed during my coilover install. I was wondering, what exactly is holding together the strut to the wheel bearing piece? If the hole in both the strut and the wheel bearing is 16mm, but the crash bolt is 14mm, what is holding the two in place? I get the clamping force is holding the bolt to the strut, but how is the strut being held to the wheel bearing piece if the bolt is smaller than both holes?
Drives: Subaru BRZ
Magic.
| The Following 3 Users Say Thank You to JD001 For This Useful Post: |
Drives: Legacy GT
The friction from the clamping force. That's how any bolted connection actually works. Even with the 16mm bolt in 16mm hole, try loosening them both and wiggling things around- there's a good amount of play there.
| The Following 5 Users Say Thank You to jamal For This Useful Post: | 2Wavy (05-24-2019), nikitopo (05-24-2019), Spuds (05-24-2019), strat61caster (05-24-2019), ZionsWrath (05-24-2019) |
[insert cool phrase here]
Drives: BRZ Premium
Dude.....that's some good shit your smoking.
But seriously dude, pass that stuff over this way.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | ZionsWrath (05-24-2019) |
Benz Tech
Drives: 2017 BRZ Premium
Magnets?
The Dictater
Drives: '13 Red Scion FRS
Just don't suggest that's how wheels stay on the car. All hell will break loose.
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Captain Snooze (05-24-2019), soundman98 (05-25-2019) |
Drives: 2016 BRZ
So the two flanges of the strut are basically squeezing together the spindle and the friction keeps them in place? That makes more sense to me. So really the diameter of the bolt doesn't matter as long as it's thick enough that the bolt doesn't stretch right?
#9 | |
Drives: BRZ Premium
Your high as fuck now.
#10 |
Drives: Legacy GT
Bolts stretch when you tighten them. The important thing is having enough clamping force before the bolt starts to permanently deform or breaks (although some fasteners are designed to yield permanently at torque spec).
The OEM "16 mm" bolts are still M14 bolts, just with an enlarged shank. The threaded section is the same size and so are the torque spec and resultant clamping force. The larger bolt will stretch slightly less. Last edited by jamal; 05-24-2019 at 10:17 PM. |
| The Following User Says Thank You to jamal For This Useful Post: | 2Wavy (05-25-2019) |
#11 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Yep, bolts are actually springs. When you torque them down they stretch, preloading the spring/joint.
Slow is smooth, and smooth is fast
#12 | |
Drives: 2016 BRZ
#13 |
Dismember
Drives: 2013 Red Scion FR-S
Bolt use magic.
#14 |
Red Loctite
Disclaimer: Don't use red Loctite
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| Camber bolt + suspension bolt torque settings | LostSalad | DIY (Do-It-Yourself) Guides | 3 | 05-09-2016 09:29 AM |
| Crash bolt nut size | qoncept | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-03-2013 07:38 PM |
| Just installed crash bolt. | normanb21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 05-21-2013 04:27 PM |
| Crash bolt question | ayau | Tracking / Autocross / HPDE / Drifting | 8 | 08-17-2012 01:22 PM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
