Old 05-21-2019, 09:16 PM   #1
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Car stalling when a/c is on
Car started randomly stalling today while at low rpm in 1st gear and a few times at stop lights while in neutral.
I noticed it happens when the a/c is on, I turned off the a/c and the problem ceased.
I had my clutch replaced just yesterday, not sure how it would be related if it happens when the car is in neutral.
What y'all think?
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 05-21-2019, 09:37 PM   #2
humfrz
What y'all think?
Are you getting any codes?
It may not be related to the clutch.
If the battery was disconnected for the clutch work, the ECU may just be re-learning stuff. I'd give it a few hours/miles to settle in.
humfrz
Old 05-21-2019, 09:53 PM   #3
FRS13_
FRS13_'s Avatar
No codes.
Come to think about it I haven't driven the car much since the clutch was replaced, maybe it is just the ECU relearning and nothing more.
Old 05-21-2019, 10:11 PM   #4
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
No codes.
If the issue doesn’t go away over time there is an idle relearn process. I had a problem with my idle after tuning with random drops and surges where the car would almost stall (as the ECU gets reset after flashing a tune), and this fixed it:
As I recall (very high level)
- Disconnect battery for 10 mins.
- Reconnect battery.
- Put car into ON position for 20 seconds, not starting it. This allows the car to calibrate sensors, etc.
- Turn car OFF and wait a few seconds.
- Put car into ON position for 20 seconds again.
- Start the car and let idle for 10 mins. This will let the ECU figure out the throttle calibration for a smooth idle.
- Turn off the car for a few mins.
- Start it back up and drive around!
That should fix your issue.
JBezugs is offline   Reply With Quote
Old 05-21-2019, 10:15 PM   #5
FRS13_
FRS13_'s Avatar
Originally Posted by JBezugs View Post
If the issue doesn’t go away over time there is an idle relearn process. I had an issue with my idle after tuning with random drops and surges where the car would almost stall (as the ECU gets reset after flashing a tune), and this fixed my issue.
Thanks, sounds pretty straightforward. I'll give it a try in the morning and report back.
Old 05-22-2019, 10:25 AM   #6
WNDSRFR
Drives: FR-S,GTI
Last time I had a CEL (only time actually) I cleared the code with the OFT and when I started the car it would barely run. I had to hold my foot on the gas to keep it running. After a couple minutes it settled down and ran almost normally. I guess it was still learning for the next couple days because whenever I would come to a stop the idle would dip so low it would almost stall. It's finally completely back to normal.
Next time I have a CEL (never I hope) I'll try this procedure to save me some grief.
Old 05-22-2019, 11:14 AM   #7
tobin
tobin's Avatar
Drives: '13 BRZ
IIRC wasn't there an ECU reflash service bulletin related to this?
http://www.ft86club.com/forums/showthread.php?t=21868
S-SB-0040-13 : Intermittent RPM Drop
tobin is offline   Reply With Quote
Old 05-22-2019, 11:54 AM   #8
That only applies to the AT and is a TCM not an ECU flash. Right symptoms though.
Old 05-22-2019, 07:39 PM   #9
FRS13_
FRS13_'s Avatar
I followed your instructions and the car is no longer stalling. Very helpful info, thanks!
Old 05-22-2019, 08:38 PM   #10
JBezugs
Good Job Subaru!
JBezugs's Avatar
Glad to hear it! Enjoy the new clutch!
Old 06-03-2019, 11:09 AM   #11
cvondra
Drives: 2014 FRS SR1
Is your car still running fine after the relearn? Dealing with similar issue for a long ass time. Going to try this method but just curious if it 'stuck' or if the relearn process becomes a neccessary frequent thing.
cvondra is offline   Reply With Quote
Old 06-03-2019, 11:20 AM   #12
FRS13_
FRS13_'s Avatar
It worked fine until i installed uel headers and oft stage 2 tune like a week later and it started happening again. I did the same procedure again, the first time I tried it didn't work (my timing was off), tried again and worked just fine.
Old 06-03-2019, 11:44 AM   #13
cvondra
My pattern is once I hit ½ tank of gas it starts to get wonky and gets worse as tank drains to light. Refill with petrol and issue goes away. Using the Full Blown Walbro 485 pump kit. Bad fuel pump? Fuel pump over heating? I know the obvious answer for resolution is don’t let it get below ½ tank……that’s a PIA in the long run. Trying to find a better resolution.
Automatic Frs stalling Abe1120 Issues | Warranty | Recalls / TSB 44 09-11-2020 07:35 AM
Fuel Cut/Stalling GamboaBRZ Issues | Warranty | Recalls / TSB 7 06-13-2019 09:20 PM
2013 Auto FRS stalling? peachsnow Issues | Warranty | Recalls / TSB 11 12-26-2014 01:03 AM
Toyota mechanic stalling my car.... aghuman Scion FR-S / Toyota 86 GT86 General Forum 47 06-18-2013 05:03 PM
Not stalling? grgonium Scion FR-S / Toyota 86 GT86 General Forum 24 11-17-2012 10:26 AM
