Old 12-24-2014, 08:59 PM   #1
peachsnow
Drives: Scion FRS Ultramarine
2013 Auto FRS stalling?
I searched around the forums but haven't found an answer yet so I hope someone here can help me out. So basically what happen was, I was at a stop and then when it was my turn to go i stepped on the gas and my car stalled, i put it back in park turned it back on and it wouldn't turn on even after four-five tries. After turning back on I realized that the passenger side window button was dead so I can't use it anymore. After that my car stalled 6 more times before i finally was able to get on the freeway. Does anyone know what the problem is with my car?
Thank you!
peachsnow is offline   Reply With Quote
Old 12-24-2014, 09:20 PM   #2
BRZnut
Drives: BRZ DGM Limited
could be anything from bad gas to the Cam failure issue that has been documented with the twins. Any codes?
Old 12-25-2014, 03:04 AM   #3
humfrz
Like said, could be bad gas ...... but, I'd suggest it's time to make a visit to the dealer ....
humfrz
Old 12-25-2014, 11:13 AM   #4
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The passenger side window issue is probably just the window lock being engaged. Just press the window lock button again and the light for the passenger window will turn back on and it should work.
As far as the stalling goes, is your car stock? It could be bad gas, as I had the same issue with my car (albeit mine is manual). If it's not gas though, your car should be throwing a code which should help identify what the issue is.
- The Ancient BRZ Sacrament
by Zaku
Old 12-25-2014, 07:25 PM   #5
peachsnow
Sorry guys didn't know I got any replies. Bad gas I wouldn't think so I pump the premium gas from Chevron. As for the right hand passenger you guys know how the button lits up auto? It is completely off and my Left hand side is fine. I started up my car this morning and it wouldn't start so I thought it was my battery so I jump started it and nothing. I can't bring it to the dealer since its completely dead. I'm calling them tomorrow to see if can tow my car to the dealer.
Old 12-25-2014, 07:26 PM   #6
peachsnow
Code wise do you guys mean CEL ? I have nothing after that.
Old 12-25-2014, 09:28 PM   #7
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Not entirely related, but actually the window lock button only locks the passenger side from what the manual says. Good luck
V_86 is offline   Reply With Quote
Old 12-25-2014, 11:52 PM   #8
peachsnow
Thanks V_86. I'm hoping they can fix it I"ve never heard of any such problem happening.
Old 12-26-2014, 12:08 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Even Chevron can have bad gas. Don't let the marketing get to you!
N1rve
Old 12-26-2014, 12:10 AM   #10
peachsnow
Ohh... I thought when you guys said bad gas I thought you meant like no name brand gas lol. But would the gas really cause my car to do this much damage to my car?
Old 12-26-2014, 12:18 AM   #11
Guff
Guff's Avatar
Drives: BRZ LZR
My bad gas experience was from an Exxon; it's possible anywhere. Mine never got to the point of not starting though. Check for a vacuum leak somewhere or if there's something wrong with your MAF or MAP sensor.
by Zaku
Old 12-26-2014, 01:03 AM   #12
peachsnow
Fasure I'll give toyota a call tomorrow morning so they can tow my car to their dealership. I'll keep you guys posted.
random bogging/stalling - no cel though edsbreezy Issues | Warranty | Recalls / TSB 5 04-22-2014 09:58 PM
Stalling and Crickets are related? SCharged Issues | Warranty | Recalls / TSB 4 09-04-2013 10:59 PM
Toyota mechanic stalling my car.... aghuman Scion FR-S / Toyota 86 GT86 General Forum 47 06-18-2013 05:03 PM
Stalling as a veteran driver Mandy Other Vehicles & General Automotive Discussions 42 05-24-2013 11:17 AM
Not stalling? grgonium Scion FR-S / Toyota 86 GT86 General Forum 24 11-17-2012 10:26 AM
