Old 06-14-2013, 05:29 PM   #1
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Toyota mechanic stalling my car....
So I went in for my first oil change yesterday (As much as I'd like to do them myself, I don't want anything biting me in the ass when it comes to warranty issues, especially down the road in a first gen car). So I was told it would take about an hour and a half so I went outside 45 min later to find my car in the lot looking like something was odd. It was a little far away but I saw it rolling forward when in reverse then heard the engine starting up again, and again, (initially I was a bit stunned cause I was almost certain these guys would know how to drive stick so I didn't want to jump to conclusions). In the end by the time I ran to the car, he had stalled 5 times from what I counted and scary part is it's only what I saw, I don't know how long he'd been there or what happened before. I asked him how many times he stalled and he said once to i told him to gtfo of my car, I reported him to the service manager who fed me this bs that he could stall the car continuously for 8 hours and not do any damage. I got it in writing that he stalled 5 times but I wanted some advice.
First off, how bad is stalling?
Secondly should I pursue this matter further?
Thanks
aghuman is offline   Reply With Quote
Old 06-14-2013, 05:46 PM   #2
chutrain
chutrain's Avatar
Drives: WRB BRZ
I'd be more worried about clutch wear and if they glazed it over.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
The Following User Says Thank You to chutrain For This Useful Post:
aghuman (06-14-2013)
Old 06-14-2013, 05:56 PM   #3
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
I understand where you are coming from but you're also kind of blowing it out of proportion. I stalled the shit out of my car for a bit when I first got it and it still runs fine. From what I've been told you can't really hurt much from stalling at a take off like that. On a second note if the tech didn't know stick then he should have gotten help with the car. Sometimes people should really learn to ask for help to avoid things like this.
Ryuu0u is offline   Reply With Quote
The Following 4 Users Say Thank You to Ryuu0u For This Useful Post:
aghuman (06-14-2013), asia_minor (06-15-2013), radroach (06-18-2013), YamahaR86 (06-15-2013)
Old 06-14-2013, 06:04 PM   #4
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
It didn't hurt your car
No you shouldn't peruse it further
Your fine, it's normal to be upset as its your car.. But nothing bad happened to it.. I've worked at a lot of garages and dealerships.. I'm surprised he stalled it that much.. Wondering if he just had it in the wrong gear.. Every shop I've worked at the techs had to know how to drive a stick..
Gixxersixxerman is offline   Reply With Quote
The Following 3 Users Say Thank You to Gixxersixxerman For This Useful Post:
aghuman (06-14-2013), humfrz (06-15-2013), YamahaR86 (06-15-2013)
Old 06-14-2013, 06:06 PM   #5
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Depends how many times he actually stalled it / how he was driving it before you saw. Youve done good getting it in writing, should you notice any feels/smells of the clutch. And thats because toyota barely has any MT cars left.
chulooz is offline   Reply With Quote
The Following 2 Users Say Thank You to chulooz For This Useful Post:
aghuman (06-14-2013), TheGuyWithTheFireStorm (06-15-2013)
Old 06-14-2013, 06:10 PM   #6
Mikem53
Drives: FR-S 6MT
Thanks
You're fine.. These cars are not that fragile.. If so.. We are all in trouble..
Next time you will be better off doing it yourself. Keep the proper documentation and sales receipts for parts.. Then no warranty issues to worry about.
Let it go.. Lesson learned and move on.
Mikem53 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikem53 For This Useful Post:
aghuman (06-14-2013), YamahaR86 (06-15-2013)
Old 06-14-2013, 06:20 PM   #7
Sasquachulator
Pavement Grey
Toyota barely has any MT cars because people in NA don't like driving MT's.
Old 06-14-2013, 06:25 PM   #8
Whitigir
Drives: 450 awhp twin turbo vr4
Stalling due to in-ability to drive a MT = Worry more about your clutch being burnt. Burning the clutch is always associated to the In-ability to drive MT
Stalling will not do any damage to the car, it is basically the Engine can not turn, the Cams and Crank sensors can not read the Revolution of the engine, the ECU stop Gas and Spark, then your engine Stop. Theoretically, it won't damage your car because every parts of the engine works in syn. The crank stops due to no combustion, then everything else stops at the same engineered position. The only thing that damage your engine is
1/ Mechanical parts are no longer in Syn (Timing belt Skips teeth, bad timing belt, Broken timing belt...and more, but Timing belt is an easier example, and Broken timing Belt = Trashed Engine)
2/ Excessive Input toward the Combustion Chamber (Too much Air, Gas, Spark, Coolant, Oil) Usually These are seen in Bad or Old Engine, or Forced Induction engine without a good Tune.
Those are just some General simple reasons. No need to go in depth
Whitigir is offline   Reply With Quote
The Following 3 Users Say Thank You to Whitigir For This Useful Post:
aghuman (06-14-2013), cmspooner (06-14-2013), lazyluka (06-16-2013)
Old 06-14-2013, 06:31 PM   #9
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Really dude. Toyota has plenty of MT NA....
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 06-14-2013, 06:32 PM   #10
campy
No rice, no life
campy's Avatar
I probably would have asked the manager if there was someone there who knew how to drive manual, since I don't want you driving my car around a tight garage if you don't know how to operate it.
Your car is probably fine though. The clutches they put in these things are pretty resilient. Just bring it to a different dealership next time.
campy is offline   Reply With Quote
Old 06-14-2013, 06:54 PM   #11
Mikem53
Drives: FR-S 6MT
2/ Excessive Input toward the Combustion Chamber (Too much Air, Gas, Spark, Coolant, Oil) Usually These are seen in Bad or Old Engine, or Forced Induction engine with a good Tune.
What? The clutch isn't going to get burnt unless they are slipping it .. And that is the opposite of stalling.. Even that takes a fair amount of abuse to do and certainly not in a confined space in a garage.. Not without being noticed.
And a broken timing belt or chain doesn't mean a trashed engine.. It's by design.. A non-interference engine will not be damaged when the timing belt breaks. And #2 makes no sense at all..
The Following 3 Users Say Thank You to Mikem53 For This Useful Post:
autobrz (06-17-2013), cmspooner (06-14-2013), strat61caster (06-14-2013)
Old 06-14-2013, 07:12 PM   #12
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It was prob an inexperienced manual driver trying NOT to burn the clutch in your nice FR-S.
Not a big deal.
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
Old 06-14-2013, 07:34 PM   #13
aghuman
aghuman's Avatar
Yea I don't think I will pursue this any further. I mean, I was pretty pissed off at the time mainly because you know, how would any of you feel if you saw that happen to your car. Now that I've cooled and done research plus sought out some input I know it probably won't do any big damage (I was mainly concerned about clutch wear) and I did my due diligence by getting it in writing from the dealer in the event something goes wrong in the near future related to that. Thanks for the input fellas
Old 06-14-2013, 07:37 PM   #14
aghuman
aghuman's Avatar
Yea I didn't mean to sound like I was blowing it out of proportion, I was upset and still am sort of but mainly at the dealership for letting people like this drive it. I mean if he didn't know how to pull out of a lot, how much damage could have been done in the garage if say, he gave too much gas and let off the clutch too soon. I would also feel bad if I didn't report it knowing it could easily happen to the next persons car going in there and no one wants that.
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 10:40 PM
Stalling after full track session IShouldStudy Issues | Warranty | Recalls / TSB 22 12-13-2013 01:34 PM
Stalling as a veteran driver Mandy Other Vehicles & General Automotive Discussions 42 05-24-2013 11:17 AM
Sluggish/Stalling After aFe Intake Install FR-S Matt Engine, Exhaust, Transmission 6 01-15-2013 08:57 PM
Not stalling? grgonium Scion FR-S / Toyota 86 GT86 General Forum 24 11-17-2012 10:26 AM
