Old 03-17-2019, 11:51 AM   #1
UNCC_BRZ
UNCC_BRZ's Avatar
Drives: 2013 WRB BRZ Limited
Broken ignition coil bolt
While changing my spark plugs I cross threaded the passenger side front ignition coil bolt. It broke off just above flush. How screwed am I?
2013 WRB BRZ
Gruppe-S headers|| Borla Cat back||OFT Stage 2+
UNCC_BRZ is offline   Reply With Quote
Old 03-17-2019, 12:20 PM   #2
Pain in the ass but not horribly screwed.
https://www.aliexpress.com/item/5Pcs...E&gclsrc=aw.ds
Old 03-17-2019, 02:42 PM   #3
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
No space for that
Dr. BRZ is offline   Reply With Quote
Old 03-17-2019, 06:18 PM   #4
UNCC_BRZ
UNCC_BRZ's Avatar
Yeah definitely cant get that in there, I'm afraid they are going to have to pull the motor....so I'm probably looking at 1k to repair?
2013 WRB BRZ
Old 03-17-2019, 06:20 PM   #5
Originally Posted by Dr. BRZ View Post
No space for that
Well ok then. Extracting the bolt is a pain in the butt. Getting to the bolt to extract it is even worse!
Old 03-19-2019, 10:35 AM   #6
UNCC_BRZ
UNCC_BRZ's Avatar
$1100 to fix. That's for pulling the motor, replacing the valve cover because they couldn't get the bolt out and 2 new spark plug seals (whatever those are). I told them to just check everything at this point since the motor is out and I'm in this deep ����
2013 WRB BRZ
Old 03-19-2019, 11:56 AM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
If you have MT, mind as well get stronger clutch fork plus newer TOB, if engine is out.
Old 03-19-2019, 05:59 PM   #8
UNCC_BRZ
UNCC_BRZ's Avatar
Clutch and TOB were replaced <20k miles ago so I should be good. I'm having them check the pulleys because my engine is really chirpy on start up.
I also have a pretty unstable idle, it is all over the place from 500 to 1k , should i have them do that too?
2013 WRB BRZ
Old 03-19-2019, 06:25 PM   #9
UNCC_BRZ
UNCC_BRZ's Avatar
Here are my plus vs new. Changed at 84k miles
2013 WRB BRZ
Old 03-19-2019, 10:19 PM   #10
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Is there enough sticking out to get vice grips on it? My next suggestion is cut a slot in the bolt with a cutting wheel on a Dremel. then get a slotted screwdriver bit in a ratchet. Have someone with a pry bar apply pressure to the ratchet head while you try to unscrew the bolt. Wouldn't hurt to soak it with a penetrating oil as well.
The next step normally would be to drill out the bolt and put a helicoil in. You could try doing it with a right angle drill and stubby bits but I doubt it would be possible without lowering the motor.
just curious, does the coil have to have a bolt on it? could you wedge something between the frame and the coil to hold it in place?
fx1mark is offline   Reply With Quote
Ignition coil questions hpde_addict Engine, Exhaust, Transmission 20 05-12-2017 10:34 PM
CEL P0351 Ignition Coil A Exrald Issues | Warranty | Recalls / TSB 16 03-23-2017 11:09 PM
Ignition coil information 1quickchic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-12-2017 09:10 PM
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 01:09 PM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
