Old 04-25-2017, 12:23 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
Ignition coil questions
2014 BRZ. I encountered P0352 error code at my last track day, ignition coil B. After turning off the car and checking back a few hours later, the code went away. The code hasn't returned after commuting for a couple weeks. Two questions:
1. What typically happens after an ignition coil error code? Can it be a one off thing or does it usually indicate that the ignition coil is on its way to failure? Would it be wise to replace it before my next track event?
2. I'm seeing three part numbers from Subaru's website. Does it matter whether or not the part number exactly matches the other ignition coils? Should I use the highest part number?
http://parts.subaru.com/a/Subaru_201...10-090-01.html
The part numbers are:
22433AA650
22433AA651
22433AA652
hpde_addict is offline   Reply With Quote
Old 04-25-2017, 12:30 PM   #2
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
In for details. I had this code show up the other day beating on it on the expressway. Odd it didn't show during any track events. But showed up on the expressway for me. I ended up clearing it since it didn't affect the way it drove. Hasn't come back since. But I'm interested to see what others have to say.
pgranberg11 is offline   Reply With Quote
Old 04-25-2017, 01:35 PM   #3
humfrz
Just speculating here ...... I reckon the COP just gets so hot under certain conditions, that it skips a beat and triggers a code.
If your car is subjected to those conditions very often, you may wish to replace the coil.
If not, I would suggest just leaving it alone.
Back-in-the-day, changing the coil was a 1/2 beer job ...... one screw, two nuts, pull the coil wire.....slap the new one on, hook it up .......and finish your beer.......
humfrz
Old 04-25-2017, 01:42 PM   #4
DarkSunrise
DarkSunrise's Avatar
You can clear the code but it will typically come back. The last time my car threw a P0351 code at the track, I was data-logging and could see significant knock above 6000 RPM (-4 to -5 FLKC) once the coil went bad. Personally I'd replace the coil rather than risk detonation like that in hot track conditions. Cheap insurance. No need to match PN's - use the latest revision.
If you decide not to change out the coil, I'd highly recommend data-logging to make sure you're not getting severe detonation at the track.
2022 BRZ Build
2013 FR-S Build
Old 04-25-2017, 01:57 PM   #5
mkivsoopra
We see this pretty frequently in 86s at the track. It's time to change the coil pack. Use the latest part number for the model year of your car.
mkivsoopra is offline   Reply With Quote
Old 04-26-2017, 11:13 AM   #6
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
good to know. it's been awhile since I did a datalog. When you got yours did you get a CEL and traction control light turn on? I only got the CEL. I'll have to do some googling for the coil p/n... thanks for the info
edit: found the p/n from OP. and SHIEET 100+ dollars for a coil??? better than a blown engine I suppose.
Old 04-26-2017, 11:18 AM   #7
Chronology
Drives: 13' Satin White Pearl BRZ
I suggest you also wrap all 4 coils, just to help deflect any extra heat generated. I have noticed this more on UEL cars then EL cars, you can also swap the coil to another slot after clearing the CEL and see if it returns. I did the latter, and it kept happening so I purchased 4 new ones and wrapped them before installing, haven't had the issue yet and I DD the car and have had 5 track days so far with 0 CEL.
Just my .02
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-26-2017, 11:29 AM   #8
DarkSunrise
If I remember correctly, the first time I got both CEL and TC lights. The second time (when I was data-logging), just the CEL.
2022 BRZ Build
2013 FR-S Build
Old 04-26-2017, 11:33 AM   #9
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Any differences in between the two? I mean a code is a code and I'm going to fix it, just curious out of my own knowledge. I also plan on heat wrapping it just like someone else suggested.
also for P0353, is it safe to assume the last "3" in the code indicates cylinder 3? I think this is the passenger side, further back cylinder? thanks for everyone's input.
Old 04-26-2017, 11:38 AM   #10
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I don't think I'm ready to drop the money on all 4 coils, but definitely something to consider to see if the code follows the coil. interesting with the UEL, as I have a UEL header. I did some googling and DEI came up. Any suggestions for gold tape brands?
Old 04-26-2017, 11:45 AM   #11
DarkSunrise
No idea what the difference is between the two. You are correct for P0353. For reference here is a diagram showing cylinder location:
2022 BRZ Build
2013 FR-S Build
Old 04-26-2017, 11:47 AM   #12
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
No idea what the difference is between the two. Here is a diagram showing cylinder location though:
amazing. thank you! very helpful I always end up googling this every time since I forget. I wonder if mine got triggered due to my nasty over pipe leak. I have a 3 inch JDL over front pipe, so maybe since the pipe is bigger, it's closer to the coil, plus i had a nasty leak... I will take multiple datalogs to see if it's knocking before I buy a new one though. I still may buy one anyways to be safe.
Old 04-26-2017, 11:54 AM   #13
Chronology
I would stick with wrapping 1st, if you still have issues or a specific coil you move around causes the cell the "move" with it. Then replace.
I found whatever was cheap at Autozone, make sure you buy a roll not a sheet. I am still FI and don't think the gold wrap makes a difference in quality until you see VERY high (turbo) heat levels. I picked up a single roll, pulled all 4 and wrapped the hell out of it. Still, have a TON of the roll left.
Old 04-26-2017, 11:55 AM   #14
DarkSunrise
No problem! When you're data-logging, make sure it's in track conditions (or something close to that). I only saw the knock at the track when everything was hot and the tach north of 6000 RPM.
2022 BRZ Build
2013 FR-S Build
CEL P0351 Ignition Coil A Exrald Issues | Warranty | Recalls / TSB 16 03-23-2017 11:09 PM
Ignition coil information 1quickchic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-12-2017 09:10 PM
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 01:09 PM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
4 OEM spark plugs and 1 OEM ignition coil Kronos Engine, Exhaust, Bolt-Ons 12 07-29-2016 10:08 AM
