Old 03-15-2019, 06:21 PM   #1
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Camber issue
Hey guys! So I’m having a pretty good amount of camber issues on my front two tires. I have 17 inch wheels but same standard size tires that came with the car. Can anyone tell me a good easy fix for this? Any info would be greatly appreciated.
Twitchy313 is offline   Reply With Quote
Old 03-15-2019, 06:24 PM   #2
strat61caster
strat61caster's Avatar
What do you mean by "camber issues"?
ineedyourdiddly
Old 03-15-2019, 06:28 PM   #3
86MLR
86MLR's Avatar
Too much camber?
Not enough camber?
Camber bolts = cheap
Top hats = not so cheap
https://www.google.com.au/search?q=t...obile&ie=UTF-8
https://www.google.com.au/search?cli...60.oQqTAOwQqVE
Enjoy
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 03-15-2019, 06:44 PM   #4
Twitchy313
Twitchy313's Avatar
Originally Posted by 86MLR View Post
Too much camber?
Not enough camber?
Enjoy
Too much camber because the inside of my tires keep wearing out, thank you for the information i really appreciate it brother!
Old 03-15-2019, 06:53 PM   #5
Interlocker
Drives: 2017 Toyota 86 860
In my experience, inside tire wear is usually more a result of toe rather than negative camber.
Interlocker is offline   Reply With Quote
Old 03-15-2019, 06:54 PM   #6
86MLR
86MLR's Avatar
It may be to much toe causing added wear as well as camber, if it's just a street car get zero toe everywhere.
How low are you?
Old 03-15-2019, 06:54 PM   #7
Grady
Grady's Avatar
Could be toe issue.
What are your alignment numbers? If you do not have them go get an alignment and report back. Also what suspension changes have you made?
Old 03-15-2019, 07:11 PM   #8
Twitchy313
Twitchy313's Avatar
How low are you?
I’m at stock height, no new coils or coil overs.
Old 03-15-2019, 07:12 PM   #9
Twitchy313
Twitchy313's Avatar
Originally Posted by Grady View Post
Could be toe issue.
No suspension changes, still stock.
Old 03-15-2019, 07:30 PM   #10
86MLR
86MLR's Avatar
Unless something is bent I would assume your toe is out, stock camber is non adjustable, only toe.
I would just take it to a "good" alignment shop and see what they say.
Actually, for the price of camber bolts, I would get some and throw them in prior to getting the alignment.
Camber bolts can be a cheap and easy way to even out your camber, expesially if something is a "bit bent".
Do some research on front camber settings, it depends on tyre selection and use really, settings can range from anywhere between -1° to -2.5° for street use.
I'm currently: Hankook RS4
Front, -2.5° 0 toe (from adjustable MCA coils)
Rear, on stock arms -2.0 0 toe (from 15mm drop)
BUT, that is set up for me, could it be better, maybe, my gauge is tyre wear.
Opinions may vary
Old 03-15-2019, 07:31 PM   #11
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
VIP BRZ is offline   Reply With Quote
Old 03-15-2019, 07:31 PM   #12
Decep
Drives: 2013 FR-S Series 10
A lot of cars are toed out from the factory. Great for steering response but bad for tire life. Correctable at any alignment shop
Old 03-15-2019, 08:08 PM   #13
Grady
Grady's Avatar
Last alignment???????
Old 03-16-2019, 05:47 PM   #14
Twitchy313
Twitchy313's Avatar
Thank you guys! I appreciate all the info!
SPC Camber Bolt Issue breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-20-2021 09:22 AM
Suspension issue (Camber) Devin11498 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-04-2018 11:24 PM
SPC Camber bolt install issue AnotherDude000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-10-2017 05:59 PM
Issue with camber plate ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-02-2015 05:04 PM
FRS - Front Camber Issue HELP LikeMike86 Scion FR-S / Toyota 86 GT86 General Forum 4 06-04-2015 11:46 AM
