Drives: 96 Ek Hatch, 2015 Scion FRS
FRS - Front Camber Issue HELP
Hello there
I bought a 2015 FRS about 3 months ago. I was omw home 2 weeks ago and hit a curb going at about 30 mph. My whole lower control arm and stabilizer link got messed up, the car was not drivable. I took matters into my own hands, which might of not been wise and flat bed the car home. I ordered the parts straight from the dealer and had my mechanic install them. Didnt want to get insurance involved. The car drives fine, but the steering is a bit off . So i went to go get the car aligned today at the dealer and the mechanic told me it wasn't possible due to the car having camber on the front passenger wheel. What should i do. Any help is appreciated. |
Drives: FR-S 10 Series MT, Honda 919
Another part needs replacement or adjustment. You can try to get by as is by tightening the tie rod, and loosening the strut bolts, pushing the bottom of the tire in, and tighten. Ideally you should take a closer look at the entire strut assembly, and check torque specs.
Off Topic
You may have tweaked the frame where the lower control arm attaches.
What were his measurements for that wheel? Camber, caster, and toe. |
I didn't get the measurements, but I will be taking it to my mechanics shop to have it looked at closer. Thanks tho for the help.
Drives: FRS
did you check to see if the strut's lower mount got tweaked too?
| SPC Camber Bolt Issue | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 54 | 02-20-2021 09:22 AM |
| Issue with camber plate | ZionsWrath | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 08-02-2015 05:04 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
