Thanks
Issue with camber plate
I installed raceseng cascam on stock suspension. Had a problem with the center shock nut coming loose. The Blue Loctite fixed the issue for a bit. I did 3 events (3 days in a row) and put about 1000 miles on them and didn't have a problem.
On the drive home they started clunking badly. Same sound as when they were loose the first time, but now they are still tight and trying to tighten them does nothing and the sound is still there. It is a really awful sound and I am worried to drive the car. I checked the rest of the suspension parts and nothing is loose. The sound is definitely coming from the top part of the suspension. Is it possible I blew the shocks or something? I don't really know where else to look.
Drives: 2014 FR-S 6MT Monogram Series
had the same issue as yours with the noise not the part where they come loose. ended up removing them from my kw v3's. need to install them back again just dont want to hear the noise
Thanks
So just remove and reinstall them?
| The Following 2 Users Say Thank You to Raceseng For This Useful Post: | whataboutbob (05-22-2015), wparsons (05-21-2015) |
Junior
Drives: a car
He gotchyo back bruh.
Thanks
No luck. Everything appears tight. No evidence of anything loose like rubbing marks around any fasteners. Shocks not leaking oil.
Can not reproduce sound unless driving. Happens on bumpy roads like city streets. Silent on flat roads. Any ideas? Should I hit the center shock nut with an impact? It is tight with hand tools.
#7 | |
The spherical bearing might be loose from the first 2 times the shock nut came loose. The direct pounding on the bearing could have ruined the teflon liner.
Did you try calling the shop number I gave you to talk in person? Quote:
Thanks
Yes i spoke to ryan. Any way i can check that?
#10 |
Thanks
#11 |
You won't see internal damage on the bearing from an external shot, if you have the bearing loose you can probably feel extra play (there should be none) though.
| The Following User Says Thank You to wparsons For This Useful Post: | Raceseng (05-22-2015) |
#12 |
Thanks
I disassembled the passenger side today. Took the whole thing out.
Bearing moves smoothly. No play. No noise. Reassembled everything, new blue loctite on fasteners. Sound is still there. Occurs much more when single wheel is driving over bumps, not much if any when both wheels go over something, like an expansion joint. I noticed this damage to the spring perch. It may be from an incorrect bolt on initial install which has since been replaced but I can't be sure.
#13 |
Check your swaybar endlinks too.
| The Following User Says Thank You to wparsons For This Useful Post: | whataboutbob (05-24-2015) |
#14 |
AutoX-10/10ths every run
This. If the bolt holding the endlink to the swaybar or the bolt holding the endlink to the strut/coilover is loose, you'll get clunking when there is an uneven load on the swaybar. A case where this can happen is when you are entering a driveway and one side of the front suspension becomes loaded while the other is not. In this case there is the most extreme load on the front swaybar and if the endlinks aren't REALLY tight, you can get clunking. I've encountered this problem more than once on my car. It is a good idea to check the nuts on the endlinks from time to time as they may come loose even if you tightened them properly during the initial install. I've also found that depending on which endlinks you are running, it may be necessary to put a 3/8" fender washer on both sides of the mounting point for the endlink to get them to snugly tighten up.
| SPC Camber Bolt Issue | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 54 | 02-20-2021 10:22 AM |
| Jrz rs1 no camber plate? | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-09-2014 11:16 PM |
| ST coilover + Camber plate | BRZPDX | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-26-2014 03:11 PM |
| Raceseng Camber adj top mounts issue | kcco-whiteout | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-16-2014 03:15 AM |
| HVT BRZ/FRS Non-raising Camber Plate | Turn in Concepts | Brakes, Suspension, Chassis | 25 | 08-18-2013 04:57 PM |
