Old 01-07-2019, 11:13 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
front wheel bearing life
My front right started making some noise a couple of months ago. Dropped the car off and they say both front wheel bearings need to be replaced. Under warranty
Anyway, wondering what kind of life trackhounds are getting out of these items. I took delivery of my car 12 months ago, have done 13 track days this year, on the order of 13 track hours. Mileage is at 25,500 (massive commute).
Old 01-07-2019, 11:59 AM   #2
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I got 46k miles, 36 trackdays, and over 200 autox events before I had to replace mine (actually doing them as soon as they come in on Thursday).
14stu is offline   Reply With Quote
Old 01-07-2019, 12:08 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
Around 50 hours of track use and around 40k miles out of my front bearings. 60-70 hours of track (and same street millage, car is now a trailer car) for the rear ones. I run relatively heavy aero (at least heavy for stock power), for what its worth.
Old 01-07-2019, 01:22 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
This kinda confirms that my setup is somewhat hosed...
Because of points situation to be in T40 with COMSCC, my only mods are:
Raceseng camber plates
Swift BRZ Sport springs
17x9 wheels, 245 RE71R tires
Springs and camber plates put the car 1.5" lower in front and 1.25" lower in back (lower than the 1.1"/1" advertised for the springs). This put the front of the car *hard* onto the bump stops. So I cut bump stops way down and also added in 0.25" spacers between the front springs and the Raceseng spring perches. So now ride height is -1.25" all around.
The car still leans *heavily* on the outside front during hard cornering. Which may have actually helped me a bit on track by limiting body roll. But at the expense of ride quality on the street and front tire life at the track!
Has me thinking about a different approach this year, either:
RCE Yellow springs for stiffer front spring rate and nearly 1/2" higher ride height
or
Different camber plates that don't raise front of the car more than .25" *and* don't take away bump travel (Raceseng ones don't raise ride height at all, but looks to me like they reduce bump travel by about 12-15mm)
But reluctant to change because the weird-o setup worked great for 2018, won my class and overall championships with COM!
Old 01-07-2019, 02:29 PM   #5
RFB
RFB's Avatar
Drives: FRS
Originally Posted by ZDan View Post
Anyway, wondering what kind of life trackhounds are getting out of these items. .
5 YEARS of hard tracking, my last 100 thou on stock motor, currently doing the next 100 thou on a built motor.
15 1/2 lb., 18 in. wheels with 245 40 track tires. (Heavier set up in winter).
Lots of 200 tread wear tires and brake pads wore out, on my 4th set of discs but the wheel bearings are still original, still fine.
My ears however have never recovered from the squeeeeeeking noises of race pads.
RFB is offline   Reply With Quote
Old 01-07-2019, 03:34 PM   #6
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
86k miles, 20 track days, prob over 200 autox events and DD duty the whole time. Front right started to go and I just replaced them all. Easy and quick to change out. Fronts needed it for sure, rears might have had a few more track events before they needed to be replaced.
Shneegle is offline   Reply With Quote
Old 01-07-2019, 04:49 PM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
What's the offset on those big 17x9s?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-07-2019, 06:41 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
+40 6UL and +35 TC105n.
I don't think it's the offset though. Based on front tire wear at the track, I think it's my dynamic roll stiffness distribution moving to the front as soon as the outside front is into the bump stop, which is soon... I think my setup just loads the outside front too much.
Old 01-07-2019, 06:55 PM   #9
14stu
14stu's Avatar
I run the exact same 6UL's.
Old 01-08-2019, 09:59 AM   #10
venturaII
venturaII's Avatar
Yeah, +40 is pretty conservative, and even +35 is commonly used successfully. It definitely sounds like your suspension setup needs some refinement, though I'm not sure if it's your relative roll stiffness, or lack thereof... But in the end, being on the bumpstops certainly isn't helping anything. If adding ride height isn't an option, then stiffen up your spring rates a bit more and/or do away with the bumpstops entirely (not such a great solution, but cheap and easy enough to do to prove your theory)... Or add larger swaybars in a matched set so you don't impact the overall balance.
Old 01-10-2019, 03:05 PM   #11
Wheel bearings isn't something I see going too commonly on this platform.
Would be curious to see long term results!
Old 01-10-2019, 08:30 PM   #12
i8ur911
Drives: 17 BRZ Series.Yellow
Dan, did you notice any benefit using a "lowering spring" vs the stock spring?
Could you install a set of Koni or Bilstein dampers?
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 01-14-2019, 08:47 PM   #13
dpaqu
Drives: 2018 Gt86
I have 15k miles and 4 track days. I don't like the way my left front bearing feels. It's slightly stickier then the right front but isn't rumbling or anything. When I switch back to race pads in the spring I'll check it again.
dpaqu is offline   Reply With Quote
Old 06-16-2019, 08:15 AM   #14
atomicalex
Drives: 2018 BRZ Limited Perf Pack
Posting because after one lousy track day and 26K commuting miles, my fronts are making a racket and last night's steering test indicates I have at least one roasted front wheel bearing. Actually, it started making noise about a week before the track day, which I attributed to the Azenis running in.
Urgh.
@ZDan what is your build date?
Edit - ok, this weird. I put it up and yanked on the fronts side-side and up-down. It's not the wheel bearings. It's the right side of the rack. WTF? Oh well, at least that isn't going to self-combust. That can wait for a warranty check.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Front wheel bearing endless_pain Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 12-13-2016 06:06 AM
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 04:57 PM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 03:58 PM
Wheel Bearing Woes jwstaton Issues | Warranty | Recalls / TSB 16 01-24-2014 08:06 PM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
