Old 09-02-2013, 09:48 AM   #1
Muskokan
Drives: white Sport-tech
Wheel bearing gone at 1,500k!?
2nd week in owning the brz, and I already hear the all to familiar sound of a wheel bearing on its way out... Wtf. Gunna jack it up this week and check it out, really hoping its just a thrown wheel weight or something stupid, but It sounds exactly like that drone/ whaa whaa whaa from the bearing. I haven't even been doing any crazy driving, just a few drifts in a parking lot (wet). Amazes me a little sports car would go through one so quick, you guys doing autoX and stuff gone through any yet?
Other than that and the rattling transmission, car is so fine.
Thanks, Luke.
Muskokan is offline   Reply With Quote
Old 09-02-2013, 10:42 AM   #2
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
This is why we have warranties. My truck had a bad wheel bearing around 50k miles.
Mobius357 is offline   Reply With Quote
Old 09-02-2013, 10:43 AM   #3
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Thanks, Luke.
Every so often someone gets a bad wheel bearing. It is unlikely to be from wear even driving very hard. The other remote possibility is heavy pothole impact but you'd probably have lost a tire or wheel as well if that were the cause.
I've had a wheel bearing or two fail on several cars, it just happens. Many cars have their OEM factory wheel bearings as they get crushed. Just luck of the draw and a warranty repair.
Suberman is offline   Reply With Quote
Old 09-02-2013, 11:44 AM   #4
Muskokan
Okay thanks for the reply guys! Good to hear I shouldn't have any problems with warranty, had the thought in the back of my head it was one of the parts with regular wear that they wouldn't cover. Dunno what it is with me and wheel bearings, 2 on my last civic in just over a year.
Ps suberman our cars are twins! ( white, manual, sporttech) lol
Old 09-02-2013, 11:47 AM   #5
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
Yup. It's a Subaru alright.
TOMIMOTO is offline   Reply With Quote
Old 02-02-2014, 03:46 PM   #6
anewprelusion
Did OP figure out if the wheel bearing was on it's way out?
I too am experiencing "drone-like noise" from my wheels while traveling above ~50mph. It seems to be coming from the front end only, but I could be mistaken. I first noticed it after mounting and installing new wheels & tires (I don't think it was happening on stock wheels). I thought it would go away after the tires were broken in, but it's still there. Think this is a wheel bearing issue? Or just road noise due to tread pattern? This is my current setup...
Weds SA67R 18x9 + 36
Michelen Pilot AS/3 245/35
Alignment Specs
F - Toe = 0.00 & 0.01
Camber = -0.3 & -0.8
R - Toe = 0.09 & 0.09
Camber = -1.4 & -1.5
anewprelusion is offline   Reply With Quote
Old 02-02-2014, 05:14 PM   #7
Boxer486
Drives: small
Since we're on the topic, my Legacy's wheel bearing is going out. Anyone recommend any tried and true replacements? Obviously I'm not thrilled with the idea of OEM for wheel bearings.
Boxer486 is offline   Reply With Quote
Old 10-01-2014, 05:50 PM   #8
nfaj
Drives: 2015 BRZ limited 6MT
i have the same issue. OP did u get urs resolved?
nfaj is offline   Reply With Quote
Old 10-02-2014, 03:25 PM   #9
vividracing
vividracing's Avatar
I also thought I had a wheel bearing going out on me at around 2,000 miles. However mine was lowered on coilovers and after inspecting further, it was just a poor choice in tire selection. The front tires were beginning to cup from the negative camber I was running. Do keep in mind running a lower offset wheel does put more stress on the wheel bearing themselves and can cause premature failure.
vividracing is offline   Reply With Quote
Old 10-02-2014, 03:58 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
1500k?
Dang, I hope the engine held up.
-alex
wheel bearing
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
WTB: front passenger hub / bearing assembly sw22 Brakes, Suspension, Chassis 1 01-28-2014 12:51 AM
Thrust Bearing Going Out >(559)< FR-s Issues | Warranty | Recalls / TSB 22 06-19-2013 08:23 PM
bearing identification paraguin Other Vehicles & General Automotive Discussions 7 04-16-2013 10:18 AM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
