Old 05-11-2015, 08:06 AM   #1
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Front wheel bearing
Maybe somebody has gone thru this.
Bought a front wheel bearing for my BRZ(HA590315 from Timken), after verifying it was the "correct one" in a couple of places, what I received does not look like what I have in my car.
http://www.amazon.com/Timken-HA59031.../dp/B0031HRJ5S
You can see there is a hole for an axle.
OEM looks like this:
http://www.frsport.com/Subaru-28373C..._p_398295.html
Notice the caps.
OEM is 28373CA000.
My question is, do I remove the caps myself and install in the new bearing, or did I simply receive the wrong part?
Thanks for any help.
endless_pain is offline   Reply With Quote
Old 05-11-2015, 09:17 AM   #2
MrFabulous
Drives: Between Cars
You got the wrong part. It's not the cap that makes the front and rear wheel bearings different, there's more to it. I suggest sending what you got back. If you're ordering off Amazon go for the Centric 406.47001. That is the correct front wheel bearing, I just got two of them.
MrFabulous is offline   Reply With Quote
Old 05-11-2015, 09:20 AM   #3
sato
sato's Avatar
Drives: Dodge Patitas
Hope you get issue solved. However, may I ask how much mileage does the BRZ have, and reason for changing?
Old 05-11-2015, 09:46 AM   #4
endless_pain
Just ordered 406.47001.
Thanks much for the info.
Old 05-11-2015, 09:50 AM   #5
endless_pain
The BRZ has 17000 miles in it. The reason I'm replacing it is because I was getting a loud rumbling when turning right at the track. The rumbling sound and vibration was like going over the rumble strips on the highway that keeps you awake when you doze off.
"Dodge Patitas" no habia escuchado eso en años. lol
Old 12-13-2016, 06:06 AM   #6
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Bringing the topic back from the dead, but I may have to replace one of mine as well and I got this part number TIMKEN HA590518 for the front. It looks to be the right one. Just sharing for future reference.
Kwaziekeller is offline   Reply With Quote
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 04:57 PM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 03:58 PM
Wheel Bearing Woes jwstaton Issues | Warranty | Recalls / TSB 16 01-24-2014 08:06 PM
Rear Wheel Bearing or Normal Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-10-2013 01:08 PM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
