Old 01-23-2013, 05:28 PM   #1
silverbullet
Drives: 2013 BRZ LTD Silver
Blown wheel bearing =(
Anyone know what wheel bearing will fit these front hubs?? I hit a giant pothole so hard the other night I half expected my wheel to come off and heard the all too familiar sound of a blown wheel bearing afterwards. I'm guessing it be an off the shelf subaru part but google and searches here haven't turned up anything definitive.
silverbullet is offline   Reply With Quote
Old 01-23-2013, 05:40 PM   #2
Yellow_Jacket
Drives: Whiteout FRS
Did you switch to your spare and then heard the blown wheel bearing sound? If so, that's just the spare. Otherwise, must been a mega pothole.
Yellow_Jacket is offline   Reply With Quote
Old 01-23-2013, 05:49 PM   #3
silverbullet
No unfortunately, this was immediately afterwards. Its definitely the typical turn to one side and it gets better and turn the other way and it gets worse blown bearing sound/vibration.
Old 01-23-2013, 05:52 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Specific part I believe. Easy as pie to replace though, just get a new one from Subaru.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-23-2013, 06:17 PM   #5
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
http://y2kimports.com/index.php?page...hk=1&Itemid=53 Bearings are in the hub. I dont think they are available separate.
If you hit hard enough to damage the hub i would imagine some other parts are fucked up too. Swap the hub and get to an alignment shop.
dorifuto is offline   Reply With Quote
Old 01-23-2013, 06:20 PM   #6
silverbullet
Yeah, it should be an easy bolt in bearing but unfortunately the dealership will only sell me a complete hub, which I'm trying to avoid, but its looking like it might be my only option at this point. We'll see though.
Old 01-23-2013, 06:29 PM   #7
silverbullet
Thanks for the link. Surprisingly, there doesn't seem to be anything wrong with the alignment that would lead me to believe there is anything else damaged. The steering wheel is centered and the car tracks dead straight, but I will take a better look when I go to replace the bearing/hub and then have it aligned. Hopefully nothing else was tweaked.
Old 01-23-2013, 06:46 PM   #8
dorifuto
dorifuto's Avatar
Drives: 2013 brz
Right on, good luck dude.
Old 01-23-2013, 06:48 PM   #9
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
Id replace the hub and bearing assembly and check alignment
Jesse is offline   Reply With Quote
Old 01-23-2013, 09:39 PM   #10
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Bad luck!
GTB/ZR-1 is offline   Reply With Quote
Old 01-23-2013, 09:56 PM   #11
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Hub assembly's like $50 or so. Fairly easy to swap out, too. You may check out RockAuto.com or call a Scion dealership for pricing.
cobrabyte is offline   Reply With Quote
Old 01-23-2013, 10:34 PM   #12
HATED1
HATED1's Avatar
Drives: 86
A guy is selling 2 wheel hubs in the members classified.
HATED1 is offline   Reply With Quote
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Mind was blown today. Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 22 12-25-2012 03:54 AM
Initial d blown engine be6sti Other Vehicles & General Automotive Discussions 6 10-15-2012 09:16 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
